Wiring harness
Old Apr 22, 2004 | 06:32 PM
MaineIrocer's Avatar
Car: 1986 Iroc-Z
Transmission: Automatic
Wiring harness
Right now i have a TPI interior harness but i have a throttle body engine so things arnt working right between the harnesses?? If i found a interior harness from just a carberated would that work with the throttle body exterior harness or do the interior and exterior harnesses have to match?
Old Apr 22, 2004 | 08:05 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
What's not working right?
Old Apr 23, 2004 | 03:43 PM
Car: 1986 Iroc-Z
windows.....Door lock...Ignition....and radio...but the ignition is the big one.
Old Apr 23, 2004 | 04:32 PM
Car: 92'Camaro RS
Engine: a loud one
Why did you switch the interior harness? You're not planning on doing a tpi swap are you?, cause if you are, you didn't have to switch the interior harness. You checked out all your fuses right?
Old Apr 23, 2004 | 05:26 PM
Car: 1986 Iroc-Z
When i got the car it didnt have an engine and it hard a tune port before but i didnt have the money to spend togeather a TPI so i put a throttle body in instead!
Car: 1986 Iroc-Z
So now i think i have to switch to a different harness for the inside like one out of a throttle body car
Old Apr 23, 2004 | 05:38 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Ok when You switch different engines you will only need to change the harness for the engine. It is on the passanger side of the car. The engine Harness ties into the Body harness by the Check Engine Light or SES and power and Ground. Other than that There is absoletly no need to change the body harness unless you have a lot of broken wires or a Fire. I would E-mail S10Wildside and he should be able to help you out.
mike@s10wildside.com
He has a lot of diagrams that will show you where the enging harness connects to the Body harness.
just .02
Old Apr 23, 2004 | 09:10 PM
Car: 1986 Iroc-Z
So why wouldnt the ignition be working??
Old Apr 24, 2004 | 12:25 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
A bad fusible link off the starter. It seems that the only things that don't work, are those that operate only when the key is in the 'ON' or 'ACC' position.
Old Apr 24, 2004 | 07:40 AM
Car: 1986 Iroc-Z
so how can i fix that?
Old Apr 24, 2004 | 11:55 AM
Car: 1986 Iroc-Z
So it shouldnt matter what i have for an interior harness as long as the exterior one fits the engine?
Old Apr 24, 2004 | 04:23 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Correct. Just check for broken Wires and get out you Chillitons or hayes and check the wiring diagrams to find out where the problem lyes
Old Apr 25, 2004 | 09:36 AM
Car: 1986 Iroc-Z
ok, Thanks guy!
Old Apr 26, 2004 | 07:35 PM
Car: 1986 Iroc-Z
Do I need to change the wire on the exterior harness or the interior or both or what?? Can anyone help?
Old Apr 26, 2004 | 08:50 PM
Car: 92'Camaro RS
Engine: a loud one
Maine , i am just trying to help you out here, so bare with me......You said you put a different motor in the car..... Did you or did you not change the interior harness? I was thinking VATS but if yours is an 86' and you didn't change the interior harness it definitly can't be that.
Old Apr 27, 2004 | 08:49 AM
Car: 1986 Iroc-Z
i didnt change the interior harness the car use to have a tune port but the kid destroyed it and took it out so when i got it there was no motor in it...So I put a TBI in it out of an 88 camaro...
Old Apr 27, 2004 | 08:06 PM
Car: 92'Camaro RS
Engine: a loud one
Maine...you don't have to change a thing, just have to do what the others above have suggested.....check the wires going to the ignition and any wire ignition related for broken wires ...etc..... PITA , but it's about your only option right now.
Old Apr 27, 2004 | 08:13 PM
Car: 1986 Iroc-Z
so it could be either on the interior or the exterior??? That is the wires that i have to check?
Old Apr 27, 2004 | 08:14 PM
Car: 92'Camaro RS
Engine: a loud one
Well since all your problem seem to be interior related , i'de start there first. And pull the fuse panel down and check the contacts going in. Ikept blowing fuses one time ,couldn't figure it out for the life of me, pulled the fuse panel down and at some point when i was working on my car i must have dropped a metal clip down on it and it was laying on the terminal that was blowing and another one , found the problem that way.
Old Apr 27, 2004 | 08:54 PM
Car: 1986 Iroc-Z
none of the fuses in the fuse box are blown i checked all of them
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
