electric speedometer
Old May 24, 2004 | 09:43 PM
jumpingjakflash's Avatar
Car: 83z28; 84 z28 H.O.
Engine: 350 bored .060 xe268 cam 10.5:1 comp
Transmission: WC T-5
I've got an 83 z28 that i am putting a t-5 into and the t-5 is a WC t-5 out of a 91 rs. My 83 has the cable driven speedo and the trans is set up for electric of course. I want to know what all is required to swap in an electric speedo out of a later camaro or firebird (thinkin about firebird dash). Would i need the computer? What all wiring would i need?
Old May 24, 2004 | 11:46 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
More headache than it's worth. In order to swap in a Firebird dash, you'd need to swap in the wiring harness for it as well, then match up the wiring from it to the Camaro wiring; it's not plug-and-play. And then, the Camaro center console will need to be swapped out as well. Most of the same deal would apply to a 90-92 Camaro dash swap too, with the exception of the console.
All you need to make the existing speedo work, is a sending unit from an 83-89 T5 equipped Camaro, or 83-85 T5 equipped 'bird.
Old May 25, 2004 | 06:04 PM
racerx004's Avatar
Hey,I was just wonering what you meant by a sending unit for the cable driven speedo? I have an 84 and the cable go's directly from the tranny to the speedo and is driven by a gear in the tranny.
As far as I know the only sending units were for the electric speedos.
Old May 26, 2004 | 01:10 AM
Yeh, that's the doo-hickey I meant; the meaning got lost in the translation.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
