140 amp Alt.
Old Jun 5, 2004 | 08:17 PM
crazynights's Avatar
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
140 amp Alt.
I'm in the market for a 140 amp alt. I see Jegs has their version, summit has theirs and also there are many others available. Prices are somewhat close but which one should I get? Are there better ones or ones to stay away from?
Old Jun 5, 2004 | 09:18 PM
BOTTLEDZ28's Avatar
Transmission: A4
they should all be pretty much the same. Just make sure you get one with a lifetime warrenty on it.
Old Jun 5, 2004 | 09:27 PM
83_1/2 L69's Avatar
Car: 83 Z-28 (Original owner)
Engine: 305 CC-carb
Transmission: Richmond 6-speed, Rear:3.73
Check-out these guys:
http://www.alternatorparts.com/alternators_gm.htm
They also sell rebuild/upgrade kits!
What year is your car?
Old Jun 6, 2004 | 05:36 AM
Car: 1982 Z-28
Engine: 383
Thanks for the link. I'll definately check it out.
it's an 82 but it's not the stock crossfire motor. It now has a 350 with some upgrades.
Old Jun 7, 2004 | 11:43 AM
VetNutJim's Avatar
Car: Different One Every Day
Engine: LS1,LS6,L98,L83
Transmission: 700R4, 4060E,Turbo 350, Turbo 400
Yep:
That's where I got mine.
Get a CS-144..... it's the mo-bigger one and the one you want.
Old Jun 8, 2004 | 07:19 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
They are all NOT the same, in fact there is more junk out there now more than ever. NAPA or AC Delco is still the way to go. Another way and most times a better alternative is take the stock unit and go to an alt shop and have it rebuilt and upgraded. You can specify what parts you want especially when it comes to the bearings and the diode package. There is a lot of offshore parts going into the chain store units and they are of marginal quality at best. Warranties mean nothing if you have to change it every couple of years or sooner.
Old Jun 10, 2004 | 03:43 PM
Ragtop89's Avatar
GOOD INFO!!
Old Jun 10, 2004 | 04:18 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Eh, with the lifetime warranty its not so bad paying $100 once. Its not like an alternator is a pita to change.
Old Jun 10, 2004 | 04:33 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Only on a dark raining Sunday night. Then you will wish you had the better quality one.
Old Jun 10, 2004 | 04:49 PM
pasky's Avatar
Well, if your like every tech on here you watch for the warning signs, i've never had one just all of a sudden crap out. If you keep an eye on your voltage meter and notice the charge is going down, you will know what to expect. However, I see your point .
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
