power lock question....
Old Jun 6, 2004 | 02:40 PM
noc_81's Avatar
I have the power lock mechanism in both of my door, as well as the wiring. Is it possible to install switches somewhere and get power locks?
Old Jun 6, 2004 | 02:49 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If you have the wiring and the mechanism already in the door, then you should already have the switches there unless you have just installed the other stuff.
Old Jun 7, 2004 | 02:43 AM
noc_81's Avatar
A previous owner had done an interior switch from early to late style. Somewhere along the way, the switches disappeared. All I know is the I have wires running from my dash, through the door, and connected to a mechanism in the back of the door...
Old Jun 7, 2004 | 06:53 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The best & cheapest place to get some is a junkyard. I don't know if any auto parts stores carry them or not. I know if you go through the dealership to get them thay are not cheap.
Old Jun 7, 2004 | 02:03 PM
noc_81's Avatar
The problem is, I don't know how the whole system works. I've never seen a firebird/camaro with one installed as far as I can remember. Or are they just an electronic replacement of the original lock rod (which would seem less theft-prone)?
Old Jun 13, 2004 | 10:25 PM
noc_81's Avatar
so does anybody now the basics of the system?
Old Jun 16, 2004 | 06:09 PM
sheltonw3's Avatar
Car: 91' TRANS AM Modified
Engine: Classified
Transmission: Auto with Overdrive
I need to know too I tried to follow the GM hyrographics and I tied the wires to my inverter and they only unlock and thats all they do is just unlock!.....does anybody have instructions in just plain english!!!....not the ever famous?*&^%$#@~!#$%???....
its bad enough getting brainfarts!!!all day!!!
Old Jun 16, 2004 | 06:17 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
To sheltonw3,
Are you trying to install switches, shaved door locks, trying to repair the original lock wiring or what. I will try to help you if I can.
noc_81, is this the same problem that you have?
Old Jun 16, 2004 | 08:53 PM
sheltonw3's Avatar
Engine: Classified
I am trying to install them and I got the relay and the switch and I am evading the fuse box at all cost because there are many items already hooked into it!...I wired the actuators and grounded them and ran both power leads witht there respective inline fuses and all I got is "unlocked"....but it will not lock!.....so is there another relay needed?....or an alternative to wiring this up?
Old Jun 17, 2004 | 10:32 AM
noc_81's Avatar
I'm just wondering how they work, since I have the wiring already in the car along with both of the mechanisms.
BRoss99
Aug 10, 2025 05:08 PM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
mantaguy
Sep 1, 2015 08:39 PM
sailtexas186548
Aug 24, 2015 10:11 PM
zayne0
Aug 24, 2015 07:22 PM
