stock replacement distributor
Old Jun 7, 2004 | 03:20 PM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
we are reinstalling the wiring harness in the trans am. i have an accel distributor, i'm pretty sure it's jegs part #110-59107C. it does not have the same connectors as the original stock distributor, so the wiring harness does not plug into it. does anyone know where i can get a stock replacement distributor that with plug into the stock wiring harness?
Old Jun 8, 2004 | 09:10 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I don't believe there is one for the ccq-jet cars (H engine code) and you can't get a new one from GM anymore either.
Old Jun 8, 2004 | 10:37 PM
Diabolical's Avatar
Engine: 305HO L69
yeah, figures. what about other engine combos and other years? would an LG4 car have the same distributor as my L69? what about the TPI's and the TBI's?
Old Jun 8, 2004 | 11:02 PM
deadbird's Avatar
Engine: TPI 305/ v6
I do believe you should be able to use any lg4 distributor. IIRC they have like a 6 or 7 pin ign module in them (slept a little since I had my 84). If I'm not mistaken, the 85 TPI was the only year to use the same dist. Anything 86+ (f-body) went to the divorced coil. I do remember my parents 86 Caprice having the roller block lg4 with the cap-in coil and now that I think about it, the lg4 was still available up to 87 in the f-body. Not certain if they still used the cap-in-coil though. Don't take that as gospel though...
Old Jun 9, 2004 | 06:45 PM
AlabamaThunder's Avatar
Car: 1986 IROC-Z, 1990 RS
Engine: 383 Stroker TPI, 350 About To Go In
Transmission: 700R4 W/ Shift Kit And Stall, 700R4 W/ Shift Kit
My '86 IROC-Z came with a coil in cap.
Old Jun 15, 2004 | 10:43 PM
mypurple92rs's Avatar
Car: 86 iroc
Engine: 350 carbed
Transmission: t5
Diabolical i might be able to help you if your still looking for a dist i have one laying around here out of a 86 iroc i'm willing to sell
Old Jun 16, 2004 | 09:14 AM
Diabolical's Avatar
Engine: 305HO L69
i actually just picked one up at the junkyard on monday. thanks anyway.
Old Jun 16, 2004 | 10:18 AM
Car: 86 iroc
Engine: 350 carbed
Transmission: t5
cool just wondering how much did you pay.I have too start selling all these parts i have collecting dust
Old Jun 21, 2004 | 03:34 PM
Diabolical's Avatar
Engine: 305HO L69
i picked it up for $50 with a 99 day warranty
Old Jun 25, 2004 | 06:01 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: stock replacement distributor
Originally posted by Diabolical we are reinstalling the wiring harness in the trans am. i have an accel distributor, i'm pretty sure it's jegs part #110-59107C. it does not have the same connectors as the original stock distributor, so the wiring harness does not plug into it.
Then it's not #110-59107C because that would be a direct bolt-in for an 85 without ECM.
Without ECM in your car - any 75-up SBC or BBC with vaccuum & mechanical advance. That's 75-80 cars. 75-79 California cars. And some 80's trucks.
LG4 = L69 dist. yes. Absolutely the same. 87 received the small cap HEI, so 87 LG4 does not equal 86 LG4. My 86 L69 car had a diff. dist. than my 87 L69 car. Got it?
85-86 LB9 F-body and and 85-91 Vette L98 distributors will work for you. They just have a unique cap which is big-cap HEI style, but with 4 screw hold downs (similar to the 2 screw hold downs in 87-up small cap HEI distributors.
If it's the right year. And... 7.
jklein337
Sep 19, 2018 06:23 PM
92camaroJoe
Aug 13, 2015 06:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
marcusaw
Aug 10, 2015 08:13 AM
stalkier
Aug 7, 2015 04:49 AM
