Sealed Beam Conversions
Old Jun 11, 2004 | 11:11 AM
Black 91Z G92's Avatar
Car: 1991 Z28 Black 5.7 G92 pkg
Engine: 5.7l TPI
Hello All,
Im new to the board. Im wondering if anyone has used or even seen this product: (or any others)
http://www.eurolamps.com/eurolamps/sealedbeams.htm
After driving cars with newer headlamps, the old sealed beams in the Zjust dont seem to cut it.
Jeffrey
Old Jun 12, 2004 | 02:36 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
those are nice if you feel like doing all the wiring. i did it to my iroc's and a buddy's iroc but if you just want white lights that are brighter the silverstars are a sealed beam replacement that have alot better light output than the stockers
Old Jun 14, 2004 | 02:30 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I have silverstars in my Z. They are one of the nicer factory replacements i have used.
Old Jun 14, 2004 | 07:11 AM
Engine: 5.7l TPI
Hey guys, Thaks for the info so far. I have seen the silver stars in the parts stores at 20 bucks each. Here is the email reply that I got from Eurolamps about their product:
Hi Jeffrey,
Your factory lighting uses sealed beam headlamps...We have Sealed Beam
Conversion(SBC)tm kits which will replace your sealed beams with new
housings. Which will allow you to use replacement H4/H1 bulbs...
Our housings feature all glass lenses with european beam patterns for
maximum performance!! The kit below comes with EVERYTHING needed to convert
your headlights. Each kit comes with left & right conversions and both bulbs
(totally complete).
**Very Easy Direct Replacement install.**
Prices are as follows:
EuroLights/SBC(tm)Replacement Housings Type4656 (LOWBEAMS)
$59.00 per pair (complete kit) including your choice:
2x TypeH4-Blue/Gold SuperBright Ion
2x TypeH4-Yellow SuperBright Ion
2x NEW TypeH4 -Xenon-Charged Blue/White (Add $10.00)
EuroLights/SBC(tm)Replacement Housings Type4651 (HIGHBEAMS)
2x TypeH1-Blue/Gold SuperBright Ion
2x TypeH1-Yellow SuperBright Ion
2x NEW TypeH1 -Xenon-Charged Blue/White (Add $10.00)
Free Shipping! -- Limited time offer.
SPECIAL OFFER: Complete Package of lowbeams & highbeams conversion kits.
Includes EVERYTHING you need for easy conversion of your lowbeams AND
highbeams. $109.00 including 4 conversion housings and your choice of
EuroLights bulbs. For A Limited Time.
All models above are direct replacements for your factory bulbs...easy
install.
Here are the differences:
NEW Xenon-Charged Blue/White: True high output & optimized gas mixture
offers dramatically increased performance over factory bulbs and projects
pure white light onto the road and appears blue/white in the housings when
lit. Maximum
Performance!
Blue/Gold Ion: Ion coated bulb produces a dramatic SuperBright blue/gold
light. Appears blue/gold in the housings & projects blue light onto the
street. Coating increases actual brightness 25%.
Yellow Ion: Ion coated bulb produces a dramatic SuperBright yellow
light.Coating increases actual brightness 25%.These units offer high
performance increase especially in harsh weather such as rain, fog, snow.
All EuroLights are backed up by our----90 Day free replacement warranty.
TO ORDER:
If you'd like to order please let us know which units you'd like by email.
We will then send you an order link right away!
If you have any other questions do not hesitate in contacting us
Regards,
Peter S.
@EuroLights
Beware of Imitators...True EuroLights(tm) are NOT available anywhere else.
We are The ONLY Importer/Manufacturer of The Original EuroLights(tm).
Check out our web page at: http://www.EuroLights.com
Old Jun 14, 2004 | 08:59 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
wow those are expensive, but not impressive at all. If your serious about doing the conversion these are the housings i used as well as a few other members on the board. http://www.toucanindustries.com/inde...bs&pos=0,15,58 Im no way at all saying these are the only ones to use but the are $20 each from summit racing i have a part number if you want it, as it does not show up in their online catalog. heres
Old Jun 14, 2004 | 03:07 PM
Engine: 5.7l TPI
Yes, Please post the Eurolite part #'s for the third gen Camaro. Also does anyone know the # for the Z for lamp bulbs?
THANK YOU
Jeffrey
Old Jun 14, 2004 | 08:57 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
the part number through summit racing is TCN-070100 what are you talking about part numbers? stock is 4656 and 4651. otherwise you'll be using h4 and h1's or all h4's
Old Jun 14, 2004 | 11:36 PM
AM Racer's Avatar
For sealed beam replacements, most people I know switched to Cibie -"E" code lamps. These are European lighting pattern and use the separate H-4 bulb.
Hella brand is pretty much worthless as far as quality.
You can check with Daniel Stern lighting. He deals with strictly high quality pieces.
Old Jun 23, 2004 | 05:49 PM
theonly350z28's Avatar
Car: 1988 Camaro
Engine: 355
I have a link to company that does everything camaro and the sell a kit that is at a great price. I found it easery to doenload their catalog and look from thier. Here it is http://www.classicindustries.com/
Old Jun 23, 2004 | 11:12 PM
91Z28-350's Avatar
Care to elaborate? This is the first I've heard that Hella is sucky. Daniel Stern has stated in the past that the Hella 165mm is better than Cibie (only the 165mm). Marchal is better than Hella, but is no longer available.
Old Jun 24, 2004 | 12:31 AM
AM Racer's Avatar
My personal experience with the Hella and Cibie is like this.
I've got Hella (E Code) in 2 vehicles and Cibie(E Code) in 1.
Both sets of Hellas have discoloration and corrosion forming around the perimeter where the glass is bonded to the reflector.
The Cibie's are still as new.
This is over a period of 2 years.
From a light pattern comparison, the Cibie is more distinct ( focused) then either model of the Hella.
I forget the sizing designation, but each vehicle is different.
Old May 4, 2006 | 10:21 PM
camarobeast84's Avatar
AM Racer, are you referring to the 4"x6" clear lensed Hella enclosures and the Cibie 4"x6" partially clear lensed enclosures???
Linson
Oct 24, 2025 02:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
