ECM Trouble
Old Jun 21, 2004 | 10:06 PM
SC82TA's Avatar
Car: 1982 Pontiac Trans Am
Engine: Stock carbed 305
Transmission: Stock 200C
ECM Trouble
I tried using the paper click trick to check the engine codes today and I didn't get any codes. I have a carbed 82...I did what the Haynes manual told me, I first turned on the car then stuck the paper clip in. That was the way mentioned for carbed cars, but I also tried it when the car was off then just turning the key. Can anyone help me out, why am I not getting any codes?
Old Jun 21, 2004 | 10:40 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Did you have the SES light come on while driving or did you just want to check for codes. Also, which pins did you stick the paper clip in to check the codes. Was it the top two pins on the right side?
Old Jun 21, 2004 | 10:50 PM
SC82TA's Avatar
My check engine light has been on forever...and yeah I did the two top left like the Haynes manual said.
Old Jun 21, 2004 | 11:34 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It's the top two on the right, not the top two on the left. It is pins "A" & "B" as shown in this picture
Old Jun 21, 2004 | 11:35 PM
SC82TA's Avatar
Yeah sorry ...I mistyped on my last post, it is the top two right, just like themanual said, I guess I just had left on my mind. But I did it right.
Old Jun 21, 2004 | 11:57 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Here is a diagnostic troubleshooting chart for your problem, it is out of a 1985 firebird GM service manual and not a Haynes or Chilton's. I would send you the one out of a 1982 manual but I have not received it yet. However this is close enough to give you a general idea of the problem and how to fix it.
Old Jun 21, 2004 | 11:58 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
page 2
Old Jun 22, 2004 | 05:36 PM
SC82TA's Avatar
So what do I need to test all this stuff? A voltmeter or something like that?...and thanks thus far.
Old Jun 22, 2004 | 05:43 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
A volt meter and a jumper wire will put you in business.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
mrbird
Oct 20, 2015 03:43 AM
Jlanz55
Sep 29, 2015 08:55 AM
Lmancha96
Sep 25, 2015 08:11 PM
