Starting difficulty
Old Jul 5, 2004 | 07:37 PM
Tonyrodz's Avatar
Transmission: auto
Starting difficulty
I just bought a brand new battery for my T/A--has 650 cca's. Car won't start unless I jump it from another car. Even w/a new battery. Vats is fine.
Anyone have an idea what might be causing this and why?
Old Jul 6, 2004 | 12:34 AM
Tyler-88's Avatar
i have the same problem and i have no idea what it could be. ive read some things that deal with a hot start, but mines does it hot or cold. also read that it could be in the ingnition in the steering column
Old Jul 6, 2004 | 05:12 PM
Tonyrodz's Avatar
Transmission: auto
Anyone else have any other ideas?
Old Jul 7, 2004 | 11:47 PM
83BlackBeauty's Avatar
Car: 83 Trans Am
Engine: 5.7 (350) TPI
Transmission: soon to be 700r4
Axle/Gears: 9-bolt rear. gears? hell if i know
Wish I knew the answers too, cause I still have this problem once I wire my car up properly I can diagnose it. Check all of your connetions and grounds would be my first idea. I lost all power once because of one wire.
Old Jul 8, 2004 | 03:43 PM
Tonyrodz's Avatar
Transmission: auto
It's been such a long time since I put this car together-I forgot alot of what I did.
I know there's a big jumble of grounds on the pass side head--which are tight. and at the time I made sure all grounds had good metal to bolt to.
So you think it could be a bad ground? I turn the lights on w/the car off and they're as bright as they should be(or is it because of a seperate ground for them?).
Old Jul 11, 2004 | 12:43 PM
Tonyrodz's Avatar
Transmission: auto
Anyone have an idea?
Old Jul 12, 2004 | 07:47 PM
DeLorean247's Avatar
Car: 1982 Pontiac T/A
Engine: 350 Carb
Transmission: TH200c
Might be your starter.. I had that problem bofore.. I needed extra juice from another car or my charger to start the thing and it was my old starter going out.
Old Jul 12, 2004 | 08:50 PM
Kandied91z's Avatar
check all grounds on your block....check your starter, battery and alternator. let us know after all of that has been done.
assuming all your fuses are in and you haven't done any major electrical modifications there isn't that much to the starting process. also check your connections at your battery as well. i had a cracked clamp on one of the posts. couldn't even see it but it was causing interference with a good connection.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
