my fuse panel is dead....help
Subscribe
Aug 20, 2004 | 06:07 PM
i switched my power wire for the starter with another wire down there and now my fuse panel is dead.... what to do?
Reply 0
Aug 20, 2004 | 08:09 PM
What power wire are you referring too, the big red wire from the battery or the purple wire that completes the circuit from the ignition switch?
Reply 0
Aug 20, 2004 | 08:18 PM
the purple wire.
Reply 0
Aug 20, 2004 | 08:25 PM
The purple wire goes on the small terminal marked "S" and is on the right side of the solenoid as you look at it.
Reply 0
Aug 20, 2004 | 08:54 PM
i dont know why i switched them but i got them back where they belong. my question is about the fuse box. do i need all new fuses or what?
Reply 0
Aug 20, 2004 | 09:28 PM
Okay, I guess I should have asked in the first post. Where did you connect the purple wire?
Reply 0
Aug 21, 2004 | 08:49 AM
for some reason to the motor housing
Reply 0
Aug 21, 2004 | 05:03 PM
Okay,
What I need you to do is locate connector C100 (it is located on the driver side firewall at left foot). Remove the plastic cover over it (if there) and locate pin "G5", it will be a red wire. The fuse panel gets power from it and it is a fusible link to the starter solenoid. If there is not battery voltage at that pin, you have a blown fusible link at the solenoid.
Reply 0
Aug 21, 2004 | 07:08 PM
thanks trickster ill do that.
Reply 0
Subscribe
