Dash volt meter reading low
Old Aug 24, 2004 | 11:05 PM
89IROCZ28's Avatar
Car: 1989 IROC Z28
Engine: 305 TBI (L03)
Transmission: 700R4 w/ Corvette servo
Axle/Gears: 4th Gen, 3.23, posi, PBR
89 IROC L03
Recently replaced an alternator that was whining badly and putting out low voltage with a brand new unit (not rebuilt). Voltage at the battery w/ the engine running is ~14.5 volts. But, the cluster voltmeter indicates anywhere between 8-13 volts. Prior to the original alternator going bad it always indicated more than 13 volts. Any idea what might be going on & what I should check to solve it?
Thanks!
Old Aug 28, 2004 | 12:46 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
i just had the same problem dude. it actually is still reading between 8-13 volts. I just replaced my alt yesterday. i talked to some guys on board and one suggested that the battery be recharged. I want to see what happens with this more.
Old Aug 28, 2004 | 03:57 PM
89IROCZ28's Avatar
Car: 1989 IROC Z28
That could be the problem if the volt reading at the battery matched the gauge cluster reading. In my case they don't.
I just measured the reading and this is what I'm getting:
Reading
Condition At Battery Gauge
Ignition off 12.3 8
Ignition on 12.0 8
Eng running 14.5 13
If the battery was really at 8 volts, I would agree the battery needs charging or replacing b/c it probably wouldn't start the enging. Check yours and see if you get something similar.
I suspect some resistance between the battery and the gauge is at fault and hope it's not the cluster. I just don't know where to start looking for a bad connection or corrosion in the circuitry.
Old Aug 28, 2004 | 04:04 PM
89IROCZ28's Avatar
Car: 1989 IROC Z28
Well ... the chart didn't come out very well. Let me try again ...
Ignition off
Battery = 12.3
Gauge = 8
Ignition on
Battery = 12.0
Gauge = 8 (it may be at the low limit)
Engine running
Battery = 14.5 (where it should be while charging)
Gauge = 13 (this is low and it used to be higher before the original alternator started failing)
Old Aug 29, 2004 | 12:25 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Shouldnt the gauge read ZERO with the ingnition OFF.Maybe thats where your problem is.Something is applying current to the gauge when off,perhaps causing the low voltage reading when ON.
Old Aug 29, 2004 | 07:15 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Ignition off
Battery = 12.3
Gauge = 8
Ignition on
Battery = 12.0
Engine running
Pull the guage out, it unplugs after the bezel and plastic cover is off-the guage is held in with a couple of small screws and it just pulls out. Take off the two nuts securing a small ceramic block(resistor)on the rear of the guage and if the surface where the nuts contact looks black clean the resistor with alcohol or contact cleaner. Clean the two fingers that contact the guage threads at the dash side. Don't overtighten the nuts when reinstalling the resistor to the guage,Y can crack it. Reinstall the guage and it should read normally. It's a very common problem.
Old Aug 29, 2004 | 09:04 AM
89IROCZ28's Avatar
Car: 1989 IROC Z28
Thanks Danno
Yours is exactly the kind of information I was hoping for. I'll check that out and post the results.
Old Aug 29, 2004 | 09:09 AM
89IROCZ28's Avatar
Car: 1989 IROC Z28
84 ILE
The lowest mark on my gauge is 8 or a little below that - it doesn't go down to zero. But, your right, I don't believe there's voltage to the gauge w/ the ignition off.
Old Aug 29, 2004 | 03:06 PM
89IROCZ28's Avatar
Car: 1989 IROC Z28
Danno - You're the man!
Even though the connections didn't look bad I went ahead and cleaned them up per your instructions. I aso cleaned the spring loaded contacts that the gauge plugs into and the threaded posts on the gauge itself. Now the gauge reads as it did before. Thanks for the excellent advice!
While I had it all apart I checked the voltage at the spring contacts and found the reading to be consistently 0.5 volt lower than the reading at the battery. Interesting ... but, I can live w/ that.
Again, thanks for the help. It is greatly appreciated.
Old Aug 29, 2004 | 08:29 PM
Indy GTA's Avatar
Car: 2000 Firebird, 1988 GTA
Engine: V-6, V-8
Transmission: 4L60E, 700R4
Axle/Gears: 342,373
Good to hear you fixed the problem. I'll have to remember this if it ever happens to me.
Old Aug 30, 2004 | 05:58 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
A half a volt is pretty normal voltage drop due to the internal harness resistance.
Old Oct 4, 2004 | 07:12 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
I did this with my 83 Z28 Volt Gauge and saw noticable improvement in the gauge reading more volts.
thanks Danno!
phil
Old Oct 6, 2004 | 07:17 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Is it possible that the procedure that Danno has layed out would improve the alternators ability to sense and therefore improve the system charging. Or is it just improve the accuracy of the guage?
thanks,
phil
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
bamaboy0323
Sep 3, 2015 06:07 AM
BOOT77
Aug 10, 2015 12:20 PM
