Tach Problems!
Old Aug 30, 2004 | 08:56 PM
gogo90camaro's Avatar
Car: 91 Camaro RS
Engine: 5.7
Tach Problems!
I hve a 90 camaro RS. I just recently did a engine swap. i took the origonal 305 TBI motor out and put in a 350 TBI motor in. Everything seems to run great except one thing, my tach reads twice the RPM's of what it really is. Ex: if my engine is running at a idle of 680 rpms the tach will read about 1360 rpms. Anyone know how to solve this problem or why its doing this? Thanks Gregg
Old Sep 1, 2004 | 07:28 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
I've had this problem as well... There was a post about wiring a V6 tach with a new capacitor to make it work with a V8 so I did it, will let you know if it solved my problem when I get the damn thing to start (Thursday)!
Old Sep 1, 2004 | 07:53 PM
Car: 91 Camaro RS
Engine: 5.7
I greatly appreciate it. Please let me know how it goes. Thanks Gregg
Old Sep 8, 2004 | 06:21 PM
Car: 91 Camaro RS
Engine: 5.7
any word on if your trick worked?
Old Sep 8, 2004 | 07:03 PM
goofnrox's Avatar
When you swaped engines did you uses the same distributer/ignition system, or did you upgrade anything?
Old Sep 8, 2004 | 07:56 PM
Car: 91 Camaro RS
Engine: 5.7
I used the same Ignition system
Old Sep 8, 2004 | 08:22 PM
goofnrox's Avatar
Was thinking maybe if you had installed an MSD ir something the multiple spark may be screwing with the tach signal, but is not the case here obviously.
Old Sep 8, 2004 | 08:25 PM
Car: 91 Camaro RS
Engine: 5.7
thanks for the help!
Old Sep 9, 2004 | 12:01 AM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Sorry for not replying, had a couple of hurricanes to deal with... I'll be finished cleaning Thursday, then we are bugging-out over Ivan... Not staying around for this one!!!
Old Sep 11, 2004 | 02:12 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Well, I got her running and drove it around... Tach still reading off by a huge amount even with the new diode. My problem has to be in the tach-filter which is located inline with one of the white wires coming out of the coil plug. The correct one (mine has 2 white wires) will have a diagnostic connector about 4" from the coil that comes out of the loom cover. I still haven't traced mine all the way to the filter yet as I have 8.8mm wires, a strut tower brace, and other crap that make access very tight behind the engine. Right now I have to get her ready for a trip to Atlanta tonight. Hopefully, I'll have a home to come back too!!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
