Battery cable continuety between + and - without battery?
Old Aug 30, 2004 | 11:29 PM
JPrevost's Avatar
Car: 91 Red Sled
If you measure continuety without a battery hooked up, should there be low resistance (almost a short) when measuring between positive and negative cable ends?
I think my starter just took a crap after only 2 starts.
Old Aug 31, 2004 | 12:22 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
There will be resistance if any circuits are completed, such as having the door open and having the dome light come 'on', or the memory feed to the radio.
Almost forgot - the memory feed to the ECM as well.
MM2Robinson
Oct 1, 2017 09:16 AM
Twin_Turbo
Mar 14, 2016 10:10 PM
sahlomonic
Sep 20, 2015 07:15 PM
gta892000
Sep 16, 2015 12:37 AM
64goatman
Sep 9, 2015 01:09 PM
