Can someone quickly teach me about batteries?
Old Sep 3, 2004 | 12:27 AM
verc's Avatar
Hey all,
I'm trying to work on an '88 firebird that's been sitting for a few years, so of course the battery's dead. I'm not sure if there any hope of charging it (Battery was installed in early 2000), but I need to get it cranking so I can check compression, locate the problems, etc. So I wanted to just take a multimeter to a junkyard and find something that read 12.8 volts across the terminals. Are there different amperage batteries or something that prevents me from finding any old battery with the same size and shape as the firebird battery and using it? If so, what am I to look for?
Thanks for the help,
Ambert
Old Sep 3, 2004 | 07:08 AM
Matty377's Avatar
Car: '86 Camaro
Engine: LG4
Check the CCA(Cold Cranking Amp) rating and make sure it's either the same rating or higher than the original battery. Auto parts stores usually have books that tell you what CCA rating your car's original battery had.
You could always try charging it first though, chargers aren't that expensive and they're good to have.
-Matt
Old Sep 3, 2004 | 08:18 AM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
just grab another battery you can find and throw it in there as long as it has the some terminals on it you should be able to crank it over to do some initail testing
Old Sep 3, 2004 | 10:57 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Just use a battery charger. It will simulate a good batter. You can test everything you normally would test. Besides what are the odds of finding a good battery in a junkyard.
gta892000
Aug 11, 2019 11:16 AM
Twin_Turbo
Mar 14, 2016 10:10 PM
86IROC112
Nov 27, 2015 09:54 AM
gta892000
Sep 16, 2015 12:37 AM
Ragtop Man
Sep 12, 2015 12:23 AM
