battery is being drained
Car: '94 Z28
Engine: LT1 350
Transmission: 4L60E/A4
i have an 83 crossfire, and in about 2 days the battery will be dead, gone, nothing left in it at all. i then hooked up a meter to the battery and found out it's taking 2.53 or so amps, it's not the lights, not the fuses, and not the air conditioning compressor. i can't find what it is. anyone have any ideas on what could be drawing the current?
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Start pulling fuses one at a time and checking the amperage draw. Once you find a fuse where the drain decreases, start checking the systems associated with that fuse. BTW, the ECM can also create a battery drain in some cases.
Car: '94 Z28
Engine: LT1 350
Re: battery is being drained
Originally posted by Z28cross-fire
... it's not the lights, not the fuses...
Car: '94 Z28
Engine: LT1 350
ok, a few things, the ECM should shut off when the car is off, and same with the computer. and i just fixed the brake lights so that's not it. what else could it be?
Car: 1989 Iroc-Z
Engine: 5.7L TPI
BTW, the ECM is the computer. Last edited by Trickster; Sep 26, 2004 at 08:10 PM.
Car: '94 Z28
Engine: LT1 350
meh, the ECM is kinda different from the actual car computer. ECM is for the engine where the computer is for everything, but yeah, basically same thing. and the check with the fuses, yes we took all the light bulbs out, checked how much current was being drawn from them, and so forth. like i said, it's not the...
-fuses
-lights
-brake lights
-compressor
-fuses
-lights
-brake lights
-compressor
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
do you have an amp or anything else hooked up to your battery...i.e. aftermarket foglights, fan wiring, etc....
Car: '94 Z28
Engine: LT1 350
no, i have no after market products at the moment. it's all stock, and all of it should turn off when i turn the car off, except the radio and clock, but those shouldn't even take a forth of an amp. and i just got a horn in it, cause the steering wheel had been robbed of that, but now it's in, so i have no clue what it is.
Car: '83 Firebird S/E
Engine: The Chevy 305. with carburator
Transmission: 700R-4
You do know that the computer has a single-wire power connection plug near the battery?
More to the point, I think that you may need to try the alternator (both the heavy wire, and the nylon connector). Alternators are in-circuit all the time, and most are electronically switched on/off by supplying current to the regulator, not to the windings. This means that the regulator needs to be working in working order.
Had this issue with two cars in the past. Neither one used Delco electronics.
raymondandretti
Sep 27, 2015 06:43 PM
