Need a new alternator for the 2.8 v6 whats my options.. couldnt find shat in the serc
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
Im runnin a system .. amps pushen 1000 watts.. so i need a bigger alternator and i kno it.. i think the system killed it.. so im thinken a 140+ what would be the easiest alt to hook up with not a lot of fabrication.. money isnt an option. I kno my alt went bad because when i hooked up the new battery, it said 13.5-14. volts right away then dropped to 12.... then turned the lights on now were down to 10 and so on.. lol shes shot any opions will be greatly apprieciated!
Car: 2002 SS
Engine: Ls1
now the alt is getten worse.. you think its the alternator? i have nothing else running i turn on the heat and it barely keeps up to charge the battery.. so im taken its gotta be the alt.. where can i get one that bolts right in there, like which one
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Amazing what you can find the first place you look...
http://cgi.ebay.com/ebaymotors/ws/eB...category=33573
Car: 2002 SS
Engine: Ls1
i went to 4allstart or sumtin like that and im getten a 180 amp for 1 hundred sumtin.. that one on ebay only puts, Unit Puts Out 70-80 Amps at Idle.. i can get higher for like 50 bucks more.. so i mineaswell at 4allstart.. thanks tho!!
Hotrodboba400
Dec 10, 2019 07:07 PM
