What kind of headlight bulbs does a firebird have?
Old Oct 29, 2004 | 03:05 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Simple question, any answers?
Old Oct 29, 2004 | 03:33 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: What kind of headlight bulbs does a firebird have?
The simple answer is, call your local parts store or pontiac dealer. Sorry if that seems harsh but I tend to call 'em as I see 'em.
Old Oct 29, 2004 | 04:53 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Mine uses the rectangular ones with 3 prongs in the back.
Old Oct 29, 2004 | 05:15 PM
Car: 86 T/A
Engine: HSR 355
Re: Re: What kind of headlight bulbs does a firebird have?
I have no phone/no parts stores within 20 minutes. I imagine someone at one point has replaced their headlights and would know.
Old Oct 30, 2004 | 08:16 PM
oldschool's Avatar
Car: 1985 Pontiac Firebird
Engine: 2.8 LB8 HO
Transmission: 700R4 with OD
Axle/Gears: 10 bolt 7.625 open-factory 3.42
Firebirds use quartz halogen sealed beam headlamps as standard equipment. The number is H6052. Take your pick of the brand of lamp, GE, Wagner, Sylvania, etc...
Old Oct 30, 2004 | 08:55 PM
Car: 86 T/A
Engine: HSR 355
Thank you very much.
Old Nov 3, 2004 | 11:41 AM
Re: Re: Re: What kind of headlight bulbs does a firebird have?
You wait an entire day to get your info and you say the parts store is 20 minutes away, yet thats where you will be heading now that you have the info you need? What a waste of bandwidth. Should have taken my advice. You could have easily have done a search as well. The 6052 bulbs are as common as underwear. They fit several types of vehicles. Now that you are getting the bulb changed hopefully you will "see the light."
:lala: :lala: :lala:
Old Nov 3, 2004 | 07:19 PM
Car: 86 T/A
Engine: HSR 355
Re: Re: Re: Re: What kind of headlight bulbs does a firebird have?
P.S., my headlight bulbs aren't burned out. You know what happens when you make ASSumptions. I needed the info so I can find out the wattage to see what wiring I need to run since I'm tossing in brighter reverse lights/high beams for the jerks that tailgate me. So a 20 minute ride each way to get the part number to come home and find out it's not what I want. Thanks anyway for your useless input. :lala:
Old Nov 3, 2004 | 09:41 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Re: Re: Re: Re: Re: What kind of headlight bulbs does a firebird have?
Actually you were not that specific in your post so it was only natural for that assumption to be made about your headlights being out. If what you had wanted to know was the wattage of the lights so you could do a modification to your lights then you should have specified that in your post and you might have gotten a better response to your questions.
PATRIOTIC1911
Sep 1, 2015 07:26 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
