need some guidance with headlight switch
Old Nov 13, 2004 | 05:41 PM
Wezzeles's Avatar
Car: Camaro
i have a 1992 lo3 camaro. the headlight switch socket was cut off from all the wires and i cannot figure out how they go back. if anyone who hs their dash apart take a picture or tell me which wire goes where. the chilton manual isnt being helpful with this one.
Old Nov 13, 2004 | 10:56 PM
Vader's Avatar
This help?
Attached Thumbnails need some guidance with headlight switch-lightswitchdetail.jpg
Old Nov 13, 2004 | 11:42 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Do you know if your car had the Daylight Running Lights (DRL) on it. Vaders schematic will help you if you just have the regular lights. If you have the DRL you will need a different schematic.
Old Nov 14, 2004 | 10:14 AM
Wezzeles's Avatar
Car: Camaro
that diagram is more helpful than the one in my chilton, thanks.
the car does not have DRLs.
the diagram shows 7 wires and my car has 7 wires in that place.
but the switch itself has tabs for 8 wires.
which means i cant be sure which one is the extra tab just from the diagram.
Old Nov 14, 2004 | 10:29 AM
Wezzeles's Avatar
Car: Camaro
hey i just noticed all the little numbers that correspond to the little numbers on my switch. that is all i needed except that i cant read all the numbers off the picture. could you spend a sec and just list the color of the wire with its number. thanks
i can only see the 1,4 and the X
Old Nov 14, 2004 | 10:46 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
There will be letters on the connector and numbers on the switch itself. Here is how they will match up with each other.
Pin "A" (1) = red
Pin "B" (no number) = white
Pin "C" (2) =dark green
Pin "E" (4) = brown
Pin "F" (5) = orange
Pin "J" (6) =yellow
Pin "H" (X) = black
Please note that there is no number for pin "B" on the switch and that there is no number "3" on the switch. There is also not a pin "D" with a wire to it on the connector.
Old Nov 14, 2004 | 03:12 PM
Wezzeles's Avatar
Car: Camaro
i put it back together and it works perfectly. thanks guys
Old Mar 5, 2007 | 08:16 PM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
Thanks Trickster, that helped me today. During my lunch I installed it, took me about 50 mins to disassemble and install and assemble everything. Thanks alot now I can drive at night
tglennon11
Sep 23, 2015 05:30 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
Randomtask2
Sep 10, 2015 08:37 AM
sylentnite
Sep 9, 2015 02:55 PM
luvofjah
Sep 3, 2015 07:08 PM
