Vats -- How do i measure resistance of the key???
Old Mar 4, 2007 | 01:20 PM
BigBoi4Lyph's Avatar
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 9 bolt Borg Warner Disk Brake Posi
So i have a guy with a 89 iroc 5.7 tpi 7004r auto and a borg posi disk rear end and it starts somtomes and other times it locks itself out for a couple mins i have looked around and everyone says to find he resitance but know one says exactly how and im lost i want to buy a bypass box but i need to get the resistance reading... How??? Thanks!!!
Old Mar 4, 2007 | 04:33 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
use an ohm meter and touch each side of the resistor chip embedded in the key with the test leads, you will see the value then, should be anywhere between 100-1000 ohms
Old Mar 4, 2007 | 05:47 PM
Car: 89 Iroc
Engine: 5.7 TPI
ok thanks mine comes up with nothing when i do it
Old Mar 4, 2007 | 06:00 PM
press the test leads to the chip with a good amount of pressure.
Old Mar 4, 2007 | 09:43 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Make sure your test leads aren't touching the key and the "chip" at the same time, that will give 0 resistance, I found it was helpful to clamp the key in a vise and then check it.
Old Mar 4, 2007 | 09:53 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
If you still can't get a reading turn the meter up a scale until you do get a reading.
Old Mar 4, 2007 | 10:03 PM
Car: 89 Iroc
Engine: 5.7 TPI
Thanks i think my chepo meter is just done for ahah ill check it tommorw in autoshop. thanks guys!
This vats thing sucks i just got the car at 6pm and went to the gas station low and behold it locked me out and had to wait 15 mins lol
Old Mar 5, 2007 | 05:20 AM
you know the problem is always in the key cylinder, there are two small leads actually coming out of the tumbler and they twist and get pulled everytime it goes for a start eventually breaking connection and not sending the right resistance signal to the module. I`ve changed the tumblers and it takes some time and patience, how much is that box to delete it?
Old Mar 5, 2007 | 09:10 AM
Car: 89 Iroc
Engine: 5.7 TPI
its only 25 bucks plus shipping so less then 35 or else i would probably just replace the cylander i might down the road tho but for now..
If i bought a cylander and key would i just put my old chip in the new key so it would register the right resisance to the vats box?
Thanks all you guys!
Old Mar 5, 2007 | 10:04 AM
fbodyguy86's Avatar
Car: 92 camaro rs
took my key to ace hardware and they have a machine set up to test that
Old Mar 5, 2007 | 05:06 PM
If you replaced the ignition tumbler you would need to have it re-keyed to your original key. A good dealership parts counter guy should be able to do that for you.
Old Mar 5, 2007 | 05:30 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
You can't swap the resistor, well maybe u can never tried.. but you're suppose to buy a new key blank with the correct resistance for your car and cut it to match. Check the key first though, I've seen a few vats keys that fluctuate between different resistances when put in a vats interigator. I've fixed a few vats problems that way, others were the cylinder as mentioned above, but for as easy as it is to test you'd be stupid not to test the key first.
Old Mar 5, 2007 | 08:55 PM
Car: 89 Iroc
Engine: 5.7 TPI
Thanks again for all the help after i figured out it was easy just to do it yourselfi spent 99 cents and 15 mins of my time and soldered it in No more tripping the starter cutoff im a happy guy.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RS Reaper
Oct 17, 2018 07:52 PM
Gunner242
Dec 25, 2015 04:49 PM
Linson
Oct 1, 2015 09:50 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
