Wiring power antenna
Old Nov 24, 2004 | 11:51 AM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
I wired in a new aftermarket power antenna. It works and everything but it only goes down when i turn the car off. How can i wire it so it goes down when i turn the radio off? so i can go through the car wash (reason i needed to replace the original antenna).
Old Nov 24, 2004 | 05:02 PM
69-er's Avatar
Is your stereo factory stock? According to my '83 service manual, there should be a pink wire coming out of one of the three main connectors on the stereo. Instead of connecting the antenna trigger wire to the ignition circuit, connect it to this pink wire.
If it's an aftermarket stereo, it might have a pink wire and blue wire. Pink is for a power antenna and blue is for an amplifier.
Larry
Old Dec 2, 2004 | 04:10 PM
trueburton's Avatar
I think i wired it to the same wire as what supplies the radio with power. The one that is only hot when ignition is on. If i hook this up to a pink wire it will make the antenna go down if i turn the radio off but ignition is still on?
PS yes it is aftermarket radio
Old Dec 2, 2004 | 06:13 PM
Chevmdnss's Avatar
Car: 91 Caprice Wagon
Transmission: soon to be T56
NO, NO
If you have a late model decent brand aftermarket, there will be a BLUE wire for Power Antenna, and a BLUE/WHITE for amps.
Old Dec 5, 2004 | 02:47 PM
trueburton's Avatar
yes it is a "decent" radio. it's like a $400 kenwood. I tried to hook it up to the blue wire but i think it didn't work. There are three wires coming off the power antenna which one do i hook up to the blue wire?
Old Dec 5, 2004 | 04:02 PM
Chevmdnss's Avatar
You said it only goes down when you cut the car off?
take whatever wire you have wired to ignition, remove it and wire it through a fuse, to the blue. Now it should go down when you change from FM to CD or when you turn the unit off
Old Nov 17, 2010 | 02:12 PM
dansm's Avatar
Car: 95 camaro z/ 90. 350. irocz
Engine: lt1 on 95. 350 tpi on 88 iroc
Transmission: auto on both
Axle/Gears: 9 bolt On Iroc.10 on 95 Z
Re: Wiring power antenna
Hello i bought a aftermarket power antenna for my 88 iroc it now has a power antenna but after the car shuts off the antenna is still running so i unpluged it from the relay.i was thinking of pluging the after market antenna wires in to the ones that go into the relay there are three wires green and blue and white can anyone tell me what they are like which one is ground and hot .thank you
Vintageracer
Jan 10, 2020 05:33 PM
Bert87
Aug 23, 2015 03:50 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
stalkier
Aug 13, 2015 12:59 PM
ZsTransAm
Aug 11, 2015 07:30 PM
