Electric Door lock trouble
Old Dec 14, 2004 | 11:47 AM
Buck89RS's Avatar
Car: 1989 RS
Engine: 2.8L MPFI Bored 30 over (Rebuilt DEC 2004)
Transmission: 5 - SPD With 3.42 open rear end
Does anyone have a wiring diagram for a 1989 Camaro V6 car with power door locks. The people I got the car from said they unhooked them because they would lock and unlock by themselves with the ignition on and off and during the night it would drain the battery. I have no idea how they did it, but i would like for them to work again. Thanks
-Buck
Old Dec 14, 2004 | 03:38 PM
Ozzy88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
This diagram is for an 86 but it should be the same:
http://92b4crs.tripod.com/86wiring/dia-pics/130-0.jpg
-Ozzy
Old Dec 14, 2004 | 03:41 PM
Buck89RS's Avatar
Car: 1989 RS
Nothing comes up.
-Buck
Old Dec 14, 2004 | 03:54 PM
Ozzy88GTA's Avatar
Engine: 5.0 TPI
You might have a popup blocker turned on, the link opens a new window.
If not then try the TGO home page and go to the Technical Articles, then under the Electrical section lookup the 86 Wiring Diagrams.
Old Dec 14, 2004 | 04:11 PM
Buck89RS's Avatar
Car: 1989 RS
Thanks. Got it.
-Buck
Old Dec 14, 2004 | 06:17 PM
meridius's Avatar
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
after you get it hooked back up and if it does what the people says it does try unhooking one switch then the other, I work at a pontiac dealer and had a car do the exact sme thing because a switch went bad, just a suggestion.
Old Dec 15, 2004 | 07:59 AM
Buck89RS's Avatar
Car: 1989 RS
Thanks. Can the switch be unhooked without going into the door? I didnt get a chance to go down to the garage last night. So i didnt trace my wires yet.
-Buck
Old Dec 15, 2004 | 04:25 PM
meridius's Avatar
yeah you can ucan take it off without taking the whole panel off, all you need to take off is the black trim around the handle where the switch actually is.
Old Dec 15, 2004 | 04:39 PM
Buck89RS's Avatar
Car: 1989 RS
I should have remembered that cause i replaced one of my windows. Thanks
-Buck
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
g.l.mos
Aug 22, 2015 12:02 AM
