Attn Trixter
Old Feb 28, 2005 | 02:50 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Attn Trixter
I need a wire diagram of behind the dash i need to know were a orange and pink wire hook into i dont know were the other end of the connector is it is located behind the cig lighter. Also if you have a diagram of the grounds starting from were the radio gound connects to the frame by your right knee.
Old Feb 28, 2005 | 10:43 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I will have that for you tomorrow.
Old Mar 2, 2005 | 10:39 PM
FAST RS's Avatar
Anyone. Im gonna brake down and take my car to the mechanic tommorw. My shifter and hvac control lights dont work hald my guage lights dont work. I get a loud BUZZZZZZ from my rear defoger and when i turn my lights on my turn signal lights stay on on the dash along with it sayin my high beams are on when they are off. I also dont know what the 2 wire connector goes to oh well at least it willg et fixed and ill have my window motor fixed while it is in the shop
Old Mar 2, 2005 | 10:59 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Sorry Fastrs, here is that schematic of the ground sires under the dash. I have not been able to locate that orange/pink wire that you have mentioned as of yet.
Old Mar 2, 2005 | 11:02 PM
FAST RS's Avatar
I was just feeling around and pulled that wire up. never even seen it before.
Old Mar 2, 2005 | 11:10 PM
FAST RS's Avatar
I wonder what the poblem becasue in sence by looking at that if it was the ground non of my lights woould work in the car correct?
Old Mar 3, 2005 | 12:01 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Not neccessarily, if you will notice that there are several round dots there with wires branching off from them. Those are splices so one wire feeds many. If one of those wires in the splice breaks it won't affect all the other systems. BTW, there is a wire in my Iroc in the same location only the wires are orange and brown. They are not connected to anything and I don't have a wiring problem.
Old Mar 3, 2005 | 12:04 AM
FAST RS's Avatar
At least this problem will finaly be addressed ive been messing with it when it acted up before but now it has finaly acted up to the point it needs to be addressed
Old Jun 11, 2005 | 04:39 PM
Black_Widdow's Avatar
Car: 05 GTO, 88 GTA, 98 SS
I found this old post while doing a search. Does anybody know what the orange and pink wires connect to yet?
Old Jun 12, 2005 | 01:50 AM
FAST RS's Avatar
It had nothing to do with my problem i jsut had a bad ground but i have no clue what those wires or connector go to i just was feeling back there and pulled it out.
Old Jun 14, 2005 | 05:01 PM
Yeah, same here. I know it must not be important, but I'm so curious as to what it was meant for.
R3500
Aug 24, 2015 09:05 AM
zippinz
Jul 10, 2007 11:14 PM
Trixter
Jul 18, 2006 12:31 AM
NEEDAZ
Car Audio
Jun 23, 2005 07:15 AM
