Factory Harness Connectors
Old Mar 14, 2005 | 02:13 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Where can I get new connectors for various sensors? I was fixing a broken vacuum line today and broke the connector for the MAP and my Fan Switch connector was apparently broken by the last owner. If I can still get them from GM, part #s would be great.
Also, any special tools that I'd need (besides the WeatherPack tool that Summit sells... if I even need that) to replace these connectors?
TIA.
Old Mar 14, 2005 | 03:09 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
MAP connector part# 12085502.
Fan switch connector part# 12102621.
Both of these come with leads and butt connectors to splice into the harness. For a clean install I would get the weather pack tool and reuse the stock wiring in the new connectors.
Old Mar 14, 2005 | 04:47 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Thanks!
Yeah, I planned on using the wiring that's there, it loosk ok... and I'd rather NOT do any splicing.
What's your source for the PNs, BTW, may be handy in the future to know where I can look this stuff up (I have the 82-92 Parts Catalog, but didn't know what group to even start with).
Old Mar 15, 2005 | 10:56 AM
dyeager535's Avatar
Car: Which one?
Engine: 355
Transmission: 465
Unfortunately (or fortuantely when plugging things in) the weatherpack connectors are keyed. If you buy from the aftermarket, you won't get ones that are keyed correctly. You can cut the plug with a groove that works.
The part numbers given look like GM numbers to me.
I bought stuff from these guys: weather packs
Really happy with the service, best prices I found too. Make sure to buy plenty of the pins, even if you end up with extras, cheaper than trying to find it locally!
Again, these won't be keyed for things like TPS and MAP, but that can be rectified with a razor blade. If you buy a "pair" of connectors, then no issues, but most things are dead-ended in the wiring harness.
Old Mar 16, 2005 | 07:22 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Re: Factory Harness Connectors
TIA.
Go to www.acdelco.com they list all the connectors and they come preassembled. They usually run around 15-20 bucks but it eliminates dealing with the weatherpack.
Old Mar 17, 2005 | 12:01 PM
S10Wildside's Avatar
I have just about every connector for the thirdgen engine harnesses. I've been building brand new TPI harnesses for a few years, so I have large quantities. I could put together a pigtail (like GM often does), or sell the individual components (connector, terminals, cable seals, terminal position assurance locks, etc). If you're interested, please contact me privately because I am not permitted to sell anything in the forum. mike@s10wildside.com
Old Mar 19, 2005 | 10:12 AM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Thanks to all. I've got the two new, I'll keeps you in mind this summer, I'll probably need some others.
Old Apr 23, 2006 | 06:23 AM
jlamprecht's Avatar
I've used Waytek Wire : Electrical Wiring Supplies & Industrial Products and I've been very happy. Their parts are very cheap, but you have to buy at least $5 of each component. I guess you'll always have extras.
Vintageracer
Jan 10, 2020 05:33 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
fbirdroller
Sep 2, 2015 10:27 PM
