Mystery connector
Old Mar 22, 2005 | 11:57 AM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
Mystery connector
Does anyone know what the green connector in these pictures is for? There doesn't appear to be anything else within reach for this connector to latch on to.
Old Mar 22, 2005 | 11:59 AM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
hmm how about under hood light?
Old Mar 22, 2005 | 12:24 PM
Nate86's Avatar
Engine: 4 cylinder
My car doesn't have an underhood light, and the connector is too short to reach the hood anyway.
Old Mar 22, 2005 | 04:44 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
That is the test connector for the A/C system.
Old Mar 22, 2005 | 09:13 PM
Nate86's Avatar
Engine: 4 cylinder
Test for what?
Old Mar 29, 2005 | 10:04 PM
BruceEmbry's Avatar
Car: 82 Ponitac Firebird
Transmission: 4L60e/TCI TCU
This is the test connector use to check the air-fual ratio on Computer Command Control(ECM) for LG4 and other carb engines installed in the Third Gens. I had this connecter on my 1982 Firebird with the LG4 connector.
Old Mar 30, 2005 | 07:20 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Bruce is exactly correct! Connect a dwell meter to that connector and it will tell you the frequency of the Mixture Control Selenoid that is located inside the carb.
Old Mar 30, 2005 | 01:33 PM
tommy z-28's Avatar
Car: 1985 z-28
Engine: 350ci
Transmission: 700-r4
Other connectors/relay
The circled connectors, what are they for?
If they are for the AC.....
If I have deleted my AC system can I cut these out of the wiring harness?
Attached Thumbnails Mystery connector-c-documents-settings-gentilej
Old Mar 30, 2005 | 07:21 PM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
well the round one is to the AC low pressure switch so yeah you can do away with that if you want but the other one is to the blower relay ?resistor so youll need it for the blower to operate properly.
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
