fuel pump relay wiring
Old May 17, 2005 | 05:54 AM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Transmission: 700-R4
Axle/Gears: 9 Bolt 2.77
The other day I tried to start my car (carb setup) and it started but shortly stalled. I tried to start it again and the same thing. So I waited and tried again...this time nothing. It just would crank over. So I thought maybe the fuel pump went bad. I started to check all the fuses in the fuse block and they were good. But I noticed something connected to the fuse block by terminals. It was just plugged in with a fuse. Not sure what it is or why it is there but it doesn't make much sense. It almost looks like a bigger fuse. Also from reading this board I found out there should be a fuse by the battery for the fuel pump. Well my battery has been relocated to the hatch but near the fuel pump relay I noticed a weatherpak with a fuse spliced into the fuel pump relay and it goes through the firewall and plugs into the fuse block much like the other piece. It seems to be plugged into the accessory fuse. By the way, the fuse that was spliced into the relay was a 5 amp and good. I just want to know if this wiring sounds right. And what should I check for to make sure it actually is the pump that went bad. Also, it seems I dont have the computer port...at least not where I think it should be. Is there a connector or something I can probe to see if power is getting to the pump?
I had some photos but they are too big. I'll have to take them over. I'll post them when I get them.
Old May 17, 2005 | 06:04 AM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Here is the fuse that was hooked into the fuse block. It has two terminals and was hooked into 2 different fuses.
Old May 17, 2005 | 06:06 AM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Here is my fuse block. After looking where the wiring is connected it seems to be hooked into the "radio feed" fuse. Why it's hooked into here I have no idea. I believe this wire is the one that connects to the fuel pump relay. This is where it has always been so why it would make the fuel pump act up I don't know, if in fact it is the wiring.
Old May 17, 2005 | 06:07 AM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Here is a photo of my fuel pump relay and the weatherpak with fuse next to it. It's a 5 amp.
Old May 17, 2005 | 06:08 AM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
pic
Old May 17, 2005 | 10:33 AM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Nobody can help me out here? I know someone has to know a little bit about this.
Old May 17, 2005 | 11:00 AM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
What type of fuel pump, external or in-tank?
What engine setup did the car come with originally?
And the big question, does the fuel pump have power when you key up the car or when you crank it?
BTW, that relay setup looks like it has been added on to your car, not factory.
Old May 17, 2005 | 03:53 PM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
In tank fuel pump, stock.
5.0L Crossfire Injection
Now SBC 400 Carb setup.
I don't hear the pump kick on, although I used to. Not sure if it's getting power. I just got home from work so I will take a look at it and see. I used to hear it when I would turn on the key.
Not sure if it is factory or not. I know that originally the fuel pump relay should be in that vicinity. Along with the A/C relay, and MAP sensor...both long gone. Anyway, I've read stock there was a fusable link for the pump near the battery. The battery has been relocated to the hatch, however there is a fuse wired into the relay as you can see in the photo. This must replace the fusable link originally there.
RazorN8
Jan 7, 2022 11:44 AM
89GTAOz
May 16, 2020 09:31 AM
Infested
May 22, 2018 11:56 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Kaweh
Aug 9, 2015 02:54 PM
