Battery almost dies when ACC fuse is in
Old Jun 4, 2005 | 09:27 PM
Aggp18's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
alright, for the longest time my interior light has not worked, and me either being to lazy to change the bulb or the fuse it has sat un-working. until today I had some time so I swapped them both out for working pieces, then when i started my car I noticed that the battery guage is reading almost in the red. i take out te fuse, and it goes back to normal operating range. any suggestions?
Old Jun 4, 2005 | 11:27 PM
Javelin3o4's Avatar
Car: 1971 Camaro
Transmission: TH350
sounds like a short somewhere, i had a similar issue where it would drain my batt, for me it was the acc circut w/ the door locks it was a bad lock relay i just disconnected the relay for now. I would find out whats on that circut and start trouble shooting.
Old Jun 5, 2005 | 10:54 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
When you had the bulb in, did it work? If it did work, did it stay on with the door closed or did it go off? BTW, the fuse for that light powers several different circuits.
Old Jun 19, 2005 | 04:56 PM
Aggp18's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Sorry for the lengthy reply, the bulb operates as it should when the fuse is in. When the car is on, all the accesory lighting dims very bad, and the voltage meter for the battery drops below the middle of the gauge almost into the red.
Old Jun 23, 2005 | 04:14 PM
Aggp18's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
anybody? no? please? help?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
gta892000
Aug 11, 2019 11:16 AM
Johnoooooo
Sep 22, 2015 08:55 AM
gta892000
Sep 16, 2015 12:37 AM
64goatman
Sep 9, 2015 01:09 PM
