Speedometer
Old Jul 16, 2005 | 12:05 PM
brew_crew_011's Avatar
Car: 1988 Camaro
Engine: chevy 350
Speedometer
My speedometer and odometer dont work on my '88 camaro. It has a 350 chevy out of a '77 camaro and a 700r4 transmission. I've went back and read the posts about speedometers but still cant figure it out. please help!
Old Jul 16, 2005 | 12:33 PM
92droptop's Avatar
Car: 1992 Camaro RS Convertible
Engine: 3.1
I had a similar problem. bottom line is this, your odometer doesn't work cause your speedometer doesn't work. I have a 92 so mine was an electrical unit and the problem ended up being a fried resistor in the circuitry on the back of the dash unit. Since yours is an 88, i believe it should be a mechanical speedo, so i would start by checking that the cable hasn't pulled itself out of the housing in gauge panel. After that, you might want to check to see that the cable isn't kinked. hope this helps...
Old Jul 16, 2005 | 01:49 PM
Car: 1988 Camaro
Engine: chevy 350
Thanks for the help, i'll try to fix it and get back to ya.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
