Auto Meter Tach
Old Jul 20, 2005 | 07:27 PM
19IROC87's Avatar
Auto Meter Tach
i have a 87 305 IROC-Z and i put a 5" auto meter tach in it but i dont know what wire to tap into on the ignition coil ther are 2 white and 2 pink wires, and i know it needs to go to the negitive but i dont know what wire needs to be taped into ????
Old Jul 20, 2005 | 08:26 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
You are going to want to tap into the white wire that comes out of the gray coil connector and runs down to a wiring harness behind the motor (and eventually to the factory tach). The other white wire should come out of the black coil connector and just run from the ignition coil to the ICM on the back of the distributor, do not tap into this wire for your tach signal.
Old Oct 12, 2005 | 09:26 AM
Purple 92 SS's Avatar
Car: 1992 Z/28, 2000 SS, 1968 RS/SS
Engine: 355 Built a bit / LS1
Transmission: T-5 / A4
Axle/Gears: 4.10 / 2/73's
I did this, but .. heres the but..
the tach, autometer, is reading about 500 or so rpm lower than the dash tach.. which I had thought was accurate prior to putting in the Autometer. However, I know I have issues with my volt meter and suspect my temp guage.... so how do i know what my tachs are reading and which is correct?
-steve
Old Oct 12, 2005 | 11:03 AM
Benm109's Avatar
Engine: 305 TBI
What are the 2 tachs actually reading? I know you said the Autometer is reading 500 too low, but what is the Autometer showing at idle and what is the stock tach showing at idle? I'm more prone to believe that the Autometer tach is correct and that the stock tach is going bad and reading too high. Us 90-92 Camaro guys are plagued with this problem, but I think you already know that.
If this is your 305 TBI, it should idle at 600-650 when warm, for reference.
Old Oct 12, 2005 | 02:34 PM
well yea, im aware of the 91/92 issues too, and coincidently i have another tach for the purple car as well to put in it. Just havent done it yet though.
its on my 89, that ive installed this tach.. the car at idle is anywhere from 500-600rpm.. on the autometer and maybe 800 or so on the stock.. at most..
at 70 mph i compared the two today.
its a l03/a4 with 2.73's and this is what it read.
Dash 2500 rpm
Autometer 1800 rpm
so which is correct? hell if I know.. I know that it was under constant throttle, and I had the speedo at 70 on the nose long enough to make sure none of the 3 needles were fluctuating.. so thats about as accurate of an assesment as i can get under throttle. I'll try to double check the idle when warm levels later this evening.
thanks.
-steve
Old Oct 12, 2005 | 05:15 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If you want to test the tach for accuracy there are a couple of ways of doing it. 1. buy or borrow an engine analyzer that checks voltage, amperage, and rpm. Sears and several parts stores carry them rather inexpesively. 2. get a scan tool and hook it up to the ALDl, start the car and let go into closed loop mode. set the tool to read engine RPM's. Slowly press the gas pedal and compare the reading on the scan tool and your gages.
Old Oct 12, 2005 | 09:11 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
Just for reference, my 91 RS tach reads about 100 RPM more than the engine RPM at idle and about 500 RPM more than the engine when higher than 2000 RPM. The alternate RPM readings were taken from WinALDL.
Old Oct 13, 2005 | 07:53 AM
crazymex83's Avatar
Car: '88 Firebird Formula 350
Engine: L98 TPI 350
Transmission: 700R-4
What size tires are you running on your '89? You could check and see what the ideal RPM would be at 70mph that way to see what they should both be reading. Assuming that you are running 245/50/16 size tires and with the 2.73 rear gear, 0.70:1 4th gear ratio, you should be running about 1759RPM at 70MPH. So I would say that your Autometer tach is more accurate then your factory tach.
Regardless, I'm interested to see what you find out.
Old Oct 13, 2005 | 04:18 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You also forgot to mention that if he has changed to a different size tire that his speedometer would also be off.
Old Oct 17, 2005 | 09:19 AM
well unfortunately i have the cheapo rims on it.. so theyrer the old factory 15's ill check the tire size when I go to lunch today.. unfortunately been out of town until today so i havent had time to cehck or be on here
As for the gearing, Iknow its 273's and a4.. so those are definates.
The tires I'd assume to be stock replacements for teh 15 inch rims.
as for the idle when warm.. its about 500-600rpm on the autometer and about 700-800 or so on factory tach if I remember correctly.
-steve
Old Oct 18, 2005 | 06:41 AM
Tires are 215/65/15's...
ugh.
-steve
Old Oct 18, 2005 | 08:02 AM
crazymex83's Avatar
Engine: L98 TPI 350
The 215/65/15 is a 26" diameter tire so with your 2.73 gear and 0.70:1 overdrive you still should be around 1728RPM at 70mph. So your Autometer Tach is more accurate.
Old Oct 18, 2005 | 08:08 AM
crazymex83's Avatar
Engine: L98 TPI 350
actually, now that I think about it, did the transmission shift into overdrive before you looked at your autometer tach? If you looked at your factory tach first while the trans was in third gear and read 2500rpmit would be correct. If the trans then shifted into overdrive before you looked at your autometer tach and read 1800rpm they would both be correct.
At 70mph in third gear with your trans and gears you should read 2469rpm. In 4th gear you would read 1728rpm. If this is true you may want to confirm this info with another drive.
Old Oct 18, 2005 | 08:21 PM
trkklr77's Avatar
this may seem stupid and elimentry, but did you chech the tach to see if it was switched in to the 8 cyl mode. they have a small plug in the back, in it will be 2 switches. both on one side is 4cyl, one up one down is 6cyl, both on the other side is 8cyl.
my old pick up with 31" tires, 2.73 gears, 700r4 would read 1800 at 70ish
Old Oct 19, 2005 | 06:43 AM
crazymex, thanks for the info, Im pretty sure it was in 4th already, but ill double check today when i go on a 45 min trip for work. (yes, i do drive her for a daily driver and for my work trips)
Trkklr,
The tach that I have (autometer) has 2 loops of wire on the back of it, and according to the instructions for 8 cyl use, you are not supposed to cut either loop. Therefore, I didnt. Otherwise for 4 cyl use, you cut one colored loop and for 6 you cut another colored loop. But like I said I didnt cut either.
thanks for the input guys.
-steve
Old Oct 19, 2005 | 06:30 PM
trkklr77's Avatar
okay, i was told they didnt do it that way anymore. good enough
Old Oct 20, 2005 | 07:07 AM
ok, thanks.
Also, I checked the car at 70mph again..
as close as i can tell at 70 mph the factory tach reads about 2250, and the autometer right at 1800 or so rpm..
this is in fourth gear.
(od)
thanks
-steve
Old Oct 20, 2005 | 07:40 AM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Calculations you need:
https://www.thirdgen.org/newdesign/t...ulations.shtml
Old Oct 25, 2005 | 06:50 AM
well it turns out the autometer is more accurate by about 5-600 rpm at any given time. Thanks for all your help.
I recently put one in my buddys 91, and he's in pure heaven now he knows he's idling at 600 rpm instead of 1800.
-steve
Old Nov 2, 2005 | 10:58 AM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
Axle/Gears: Moser 4.56
It's not just you 90-92 guys,,, us 88 guys have them too. Totally unreliable.
Linson
Oct 24, 2025 02:00 PM
RS Reaper
Oct 17, 2018 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Linson
Oct 1, 2015 09:50 PM
Eric-86sc
Sep 28, 2015 11:37 AM
