Installing a powerseat????....
Old Jul 31, 2005 | 10:55 PM
sheltonw3's Avatar
Car: 91' TRANS AM Modified
Engine: Classified
Transmission: Auto with Overdrive
I just recieved my new powerseat motor/console and I have no clue on where to run the main power connector in a 91' trans am under the dash?....I already got the 30 amp fuse piece and all I need to know is where the power connector goes?...thanks in advance!
Old Aug 1, 2005 | 01:06 AM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
most firebirds have a accesory feed block behind the the drivers side kick panel. At least the older ones did don't know about the 90's birds
Old Aug 1, 2005 | 12:45 PM
sheltonw3's Avatar
Engine: Classified
the 90's are different from the 80's!....most things are kinda rearranged!
Old Aug 2, 2005 | 02:21 PM
sheltonw3's Avatar
Engine: Classified
Doesn't anybody know?.....where I hook up on the feed block ,my shop manual is useless!!!
Old Aug 2, 2005 | 03:26 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
On the 89 camaros late production models they were wired up in conjuntion with the door power lock harness. This mod is also true for the later years through 1992.
Old Aug 2, 2005 | 09:48 PM
sheltonw3's Avatar
Engine: Classified
thanks thats what I needed to know!!!!
Old Aug 2, 2005 | 11:04 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
By the way, the 91 firebirds did not come with the power seats with motors therefore there is no schematic in your service manual pertaining to them. There is however a schematic in section 8A-145-0 for the lumbar and bolster support system. It is run off the pwr acc circuit breaker along with a 10 amp in-line fuse. The power door locks and defogger also work off this circuit.
Old Aug 9, 2005 | 03:01 AM
sheltonw3's Avatar
Engine: Classified
Well unfortunatly I am stuck with a chiltons guide and its very confusing and I spoke with a tech guy from GM ,he said something about the possibility that my car may already have a power seat connection under the carpet and there is a slit in the carpet that would show and some kinda super thick black wire running out from under there to run a powerseat wire set up ,could this be true or just a rumor?.....this wire run could also be running straight to the trunk for the power lock release and if so I maybe able to tap into that!......so many choices!!!!
Old Aug 9, 2005 | 05:18 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
On some models they did have that wire running in that section. It would only be an orange wire running to the power source under the dash and a black ground wire going to the frame under the seat.
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
