high beams
Old Sep 6, 2005 | 12:49 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
high beams
I bought my camaro about a year ago and my high beams have never worked. My head lights work fine but when i pull back on the turn signal lever nothing happens. There is no click or anything. They used to work when the steering wheel was all the way up but not it doesent work at all. Does anyone know what is wrong or how to fix it.
Old Sep 6, 2005 | 10:05 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You need to adjust the dimmer switch on the steering column above the ignition switch. See enclosed pictures.
Old Sep 6, 2005 | 10:06 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Old Sep 6, 2005 | 10:07 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Old Sep 7, 2005 | 07:23 AM
grimmcs's Avatar
Car: 91 Camaro
Thanks a lot. I was told something to the effect of that but not as in depth. thanks a lot for the help.
Old Sep 7, 2005 | 09:11 AM
justlearning's Avatar
Car: 91 camaro 305 tbi
Engine: 305 tbi l03
i too have this same problem but dont really understand the diagrams provided very well cant make out any parts to go by if someone has a real pic they can upload showing where i need to tighted i would be very greatful!!
Old Sep 8, 2005 | 01:30 PM
grimmcs's Avatar
Car: 91 Camaro
I took off lower trim piece under the steering wheel and found the switch. The piece that i found didnt look like the one on the picture though. Is this the piece i would adjust or am i looking at the wrong one? It moves when i pull on the lever so its part of the high beam switch but i cant find where you adjust it.
sp8ty
South East Region
Sep 24, 2018 03:55 PM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
