tails not working
Old Sep 8, 2005 | 08:11 PM
curtis84ta's Avatar
Car: 1984 pontiac trans am
Engine: Block #14010209...350...80-85
Transmission: 700 R4
tails not working
ok i did a search so bare with me...short and sweet...running lights are working but brake lights do not and the signals work. (talking bout tail lights) um from what i read...theres a switch on the brake pedal. i was wondering how would you go about fixing it or is it just like a door alarm where its magnetic sort of thing... also just incase if that doesn't solve the problem what else could it be? thanks for your input.
Old Sep 8, 2005 | 08:27 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Assuming you have the correct bulbs in the socket, it could be one of the following items. The "STOP/HAZ" fuse (test by turning on hazards), common ground for the tail lights (check for corrosion or bad connection), white wire from brake switch to "TURN/HAZ" switch. BTW, the stop light switch is a push in type switch that will only stay depressed with pressure on the brake pedal. It could also be that the switch is loose in its bracket and only needs to be adjusted.
Old Sep 8, 2005 | 09:29 PM
curtis84ta's Avatar
i know i have the right lights in there (1157's)...and by pulling all the fuses dealing with lights checking and putting them back i know thats not the prob...maybe its the ground but im assuming its the switch. but ill keep in mind..white wire.
Old Sep 8, 2005 | 09:48 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Actually Curtis84TA, according to the GM service (not haynes or chiltons) manual for your car, they should be #2057 and not #1157.
Old Sep 8, 2005 | 10:26 PM
curtis84ta's Avatar
YEAH thats probably true..but i think i went to crappy tire and picked up the lights and saw the fact replacement was 1157's and 1056's for the reverse lights
Old Sep 8, 2005 | 10:31 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Camaros used the #1157's and the firebirds used the #2057's.
Old Sep 9, 2005 | 12:03 AM
curtis84ta's Avatar
is there really a diff between the two, cause they both need the offset cause of the duel filaments but other then that is one maybe brighter?
Old Sep 11, 2005 | 08:19 PM
curtis84ta's Avatar
got them fixed...it was the switch after all...the two connectors weren't connecting and the spring had lost its "spring" aka wouldn't go back and forth with the pedal....10 dollars later a new switch and bam working once again.
thanks for the help
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
LittleFranks
Aug 20, 2015 03:55 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
