30amp "breakers"
Old Sep 9, 2005 | 02:33 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
30amp "breakers"
Anyone know where I can get 2 good OE quality 30amp breaker switches. The two in the fuse box.
My blower motor stopped working so I pulled the two breakers. Swapped them and my blower motor began to work. So I bought two 30 amp breakers from work (advance auto). Blower motor works but now my power locks don't work. My defroster will only turn on for a second then clicks off.
I assume the 30amp breakers from advance can't take the load. Anyone know where I can get good ones?
BTW are they cycling or non-cycling?
Old Sep 10, 2005 | 04:34 PM
Vader's Avatar
I believe the OEM breakers were rated at 35A. Either way, the blower fan should not be drawing anywhere near 30A under normal circumstances.
Old Sep 10, 2005 | 11:21 PM
Transmission: 4l60e
If I turn on multiple accessories it will not work properly.
Right now my power locks aren't working. Switch them and everything will work...for awhile. Then something will stop. Usually the locks.
I want to try better breakers and see if that helps. The ones from advance may just be trash.
Are they cycling or non cycling?
Old Sep 11, 2005 | 11:05 AM
Vader's Avatar
"Cyclling or non-cycling?"
I'm sorry, but I'm not familiar with those terms. My 20+ years in electrical engineering has kept me somewhat insulated from the automotive electrical world and their home-grown language and descriptions of devices, so I haven't seen that description as it might be applied to circuit breakers.
If you're asking if they are supposed to be self-resetting or not, that I can understand. They should be self-resetting, and the recycle time of a purely thermal (bimetallic) circuit breaker depends heavily on the trip mode. A sustained, near-limit trip event should theoretically result in a shorter reset time, whereas a heavy overload current trip would heat the bimetal element much more, and result in a longer reset time.
This, of course, applies only to mechanical thermal circuit breakers. You can likely locate and download the thermal characteristic of bimetal breakers from a reputable manufacturer or supplier, such as Newark or Mouser.
gta892000
Sep 16, 2015 12:37 AM
zombi_360
May 24, 2014 02:09 AM
amscova
Feb 24, 2014 11:43 AM
BanjaminGTA
Jul 24, 2007 11:44 PM
ANDYZ28
Mar 5, 2002 09:40 PM
