melted wire by the battery
Old Sep 17, 2005 | 09:24 AM
st99iff's Avatar
Car: '91 RS
Engine: 305 TBI
On my 91 RS 305, there is a spot next to the battery where a bunch of wires meet. I ran a power wire there for my amp. Everything was fine for a while.
Now one of the stock wires has all of the insulation melted right off it. It's prob like a 12/14 gauge wire that goes to a little white plastic cylinder. On the other side of the cylinder the wire is thicker. I haven't yet been able to pull the wire out of the tubing to see what it goes to.
Old Sep 17, 2005 | 09:49 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
How descriptive "this wire going to these other wires". Got the color of it or color of the wire it goes to (since the insulation melted off)?
Old Sep 17, 2005 | 11:15 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Now, now Josh!!! Wanna lay odds that he bar-b-qued the fusible link at the junction block on his car?
Old Sep 17, 2005 | 11:56 AM
st99iff's Avatar
Car: '91 RS
Engine: 305 TBI
lol. It *was* a red wire. They're all red coming from that spot. the wire in front of what I think is prob a fusible link is where the insulation melted off.
How do I fix this? Autozone's website has no matches for this part for my car. Is this a dealer part? What is the best way to splice it in to prevent future mis-haps, and how do I prevent this from happening again?
...last question, sorry. Is there a fusible link that goes to anything that if it wasn't getting power would make my car run like it was never tuned up?
Old Sep 17, 2005 | 12:12 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
There is but it is linked to so many different systems that you would have to check each one seperately.
Old Oct 1, 2005 | 02:07 AM
st99iff's Avatar
Car: '91 RS
Engine: 305 TBI
if one of the fusible links was bad, would that cause the insulation to melt off? i'm thinking it might be the fuel pump relay fusible link? since this wire has been bad my car has started running progressively worse.
how many fusible links are there on a 91 305? what are they for? I have the surging problem that I have read alot about. I'm trying to see if this is somehow related.
All of this happened after a head gasket job. Do any of the wires from the junction box go near that area? Maybe one got pinched/stripped during that? What would cause the insulation to melt? Could it be robbing my fuel pump of power?
Everything tune-up wise is new except the spark plug wires, but they're not that old. New cap, rotor, plugs, fuel filter, egr valve, MAP sensor.
Sorry this is so long.
Old Oct 1, 2005 | 02:09 AM
st99iff's Avatar
Car: '91 RS
Engine: 305 TBI
sorry, also with it idling rough, the headlights flicker slightly with the rough idle
Old Oct 1, 2005 | 04:33 PM
st99iff's Avatar
Car: '91 RS
Engine: 305 TBI
well, if anybody looks at this again, here's what I tried after stopping by the local shop.
I had no idea that the fusible link was just the wire. I'm not yet sure why the link went other than it happened when a tow-truck guy tried to jump it. But I think that the fusible link that went bad was for the alternator. The wire was bad unyil right before the "fuse" so i replaced the whole thin with an in-line fuse. Now if there is still a problem, I will know because the fuse will blow or the car will start on fire.
I haven't driven it far enough to really call it fixed, but The idle/surging was suggested to be the spark plug wires after all. After replacing every part I read about in posts, that was the only choice left. It seems better.
hope this helps someone...
BRoss99
Aug 10, 2025 05:08 PM
eightsixseven
Dec 16, 2024 01:50 PM
Street Lethal
Apr 30, 2019 12:14 PM
GTAman
Mar 15, 2019 11:40 AM
