Sensor for AIR?
Car: 1989 Firebird Formula
Engine: 305 T.B.I. (Vin tag "E" = LO3)
Transmission: THM-700-R4
Axle/Gears: 10 bolt posi 3.23
Sensor for AIR?
a while back i scoped out the AIR system and was planning to gut that crap as well as my cat... but then i noticed a wiring harnes that was plugged into some delco remy thing was also connected to it and i left it alone. what is that thing and would i get a SES light if i removed the AIR system because of it?
yep thats it... wow you took time outa your day to bring upschematics for it too... thanks trickster!
What would happen if got rid of the PEDES valve?
well can i just disconnect this wiring harness for the PEDES without getting a SES light?
alrighty then, ill prob remove it next year (storin for the winter) but here is a picture of what im talking about
So if i unplug the white and green harness i wont get the SES light?
Car: 1989 Iroc-Z
Engine: 5.7L TPI
No you won't get the SES light if you unplug those wires. When you do get around to removing that system, don't forget to plug off the lines and air pump.
alrighty then thanks for your help guys
When i remove the air system next year i will get rid of every thing connected to it, the cat, air pump, and lines.
mdtoren
Aug 16, 2015 05:45 PM
