this noise..
Car: 1991 Z28
Engine: SBC
this noise..
I went to pull the black "cover" off the guages today (the trim thats around the steering wheel) and as soon as i pulled it off the car started making the noise as if i stuck the key in the ignition....that beeeeeeeeep sound. Why is it doing that and how do I stop it?
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You had to have removed something else besides that plastic trim piece. You didn't try removing anything on the column itself did you? Another question is why didn't you disconnect the battery first?
Car: 1991 Z28
Engine: SBC
nope...i just removed the top dashpad...thinking that needed to be removed to get to the guages and plus it was cracked and looks like crap...so im gunna get a new 1. Then i moved down to the trim..and as soon as i pulled it out a bit..the noise started
i didnt unplug the battery because im a retard
and now...just for future ref...the headlight switch...how do i get the black trim past that?...does the **** unscrew from the rod?
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You have to remove the headlight switch. To remove it, there is a little lever (button) on the bottom of the switch assembly behind the dash that you push in and the **** comes out.
Car: 1991 Z28
Engine: SBC
ok got it thank you.....im lookin at my tach...its not working anymore so thats why im doing all of this to begin with. Is it normal for the tach to drop past zero when the cars off....b/c when i start the car...the tach goes to zero...but doesnt move when i rev it.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It is normal for the tach to stop somewhere on the gage when the engine is shut off and then move to the operating range when the car starts. You might want to check to see if the white wire is connected to the ignition coil in the engine compartment. That is where the signal comes from for the gage.
Car: 1991 Z28
Engine: SBC
white wire to the ignition coil?...hmm can you elaborate a bit. Ive got an accel ignition box and stuff...so can you explain where this wire is
fearthisinc
Dec 11, 2008 08:49 AM
