big black with red stripe??
Old Oct 22, 2005 | 05:35 PM
tt 383's Avatar
Car: 88 t-tops
Engine: 383, tfs heads
Transmission: 700r-4
i was hoping someone could help me track this orphan down. it got cut a long time ago when the swap first started. this is for an 88 tbi car. any help would be appreciated. have looked and searched to no avail.
Old Oct 22, 2005 | 05:38 PM
tt 383's Avatar
Car: 88 t-tops
oh teh , forgot to tell the location
this comes from the top outermost harness n the drivers side.
Old Oct 23, 2005 | 11:46 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
a picture would be of a great help here in solving your mystery wire.
Old Oct 23, 2005 | 05:05 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
sounds like a/the cooling fan wire. if you have dual fans, one is probably black w/purple stripe, the other should be the wire in question - black w/red stripe.
Old Oct 23, 2005 | 05:09 PM
tt 383's Avatar
Car: 88 t-tops
sorry,
i have tried a couple of times, my files are about 24,000 bytes to big? maybe if i explain? on the firewall as you are at the front of the car, its grouped with three harnesses in the driverside corner. it is the top right harness and the smallest harness. it is maybe a 12 gauge, and their is a red of equal size also. they are the same size as the smaller red out of the alternator going to the starter.
Old Oct 23, 2005 | 05:13 PM
tt 383's Avatar
Car: 88 t-tops
thank you...
that would make sense as i havent hooked them back up yet, i cant seem to find the black/purple wire though.
Old Oct 23, 2005 | 05:15 PM
Car: '91 Z28
Axle/Gears: 323's
i'm pretty sure i know where you're talking about, but usually that size of wire is for ignition related, power distribution, or cooling fan(s) components. do you have one fan or two, and does it/they work?
i'm not completely familiar w/TBI cars, but if they have only one fan, and i believe that to be true, then chances are that your one and only cooling fan wire is the black w/red. there will be no black w/purple...
Old Oct 23, 2005 | 05:38 PM
tt 383's Avatar
Car: 88 t-tops
oh, that makes sense. hey thanks thunderstick. great site, very informative. i cant wait to get this thing running, on the road
jaridjohn
Jul 8, 2024 03:49 PM
Glowsock
Jan 9, 2017 04:06 PM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
z28_AJ
Aug 27, 2015 08:59 PM
drathaar907
Aug 10, 2015 07:44 AM
