Vats Wiring Need Help
Old Oct 29, 2005 | 10:36 PM
89tpi camaro's Avatar
Engine: 5.7 TPI
I NEED TO KNOW WHERE TO FIND PASS KEY RESITANCE I HAVE PANLESS HARNESS WITH 89 ECM ,MAF ,I HAVE THE PUR WIRE BUT I NEED TO KNOW HOW TO BYPASS
Old Oct 30, 2005 | 12:33 AM
IROC-Turbo's Avatar
Gm dealers and lock smiths have ann interigator that will tell you the key code.The dealers and roadside quite carrying the codes by using the vin--just found that out myself!!Here is a list of resistors of the 15 "codes" gm used:
Note: Here is the chart for anyone who is following this. The large number is ohms, but will show up as a decimal in kilo ohms for the 4 digit numbers. i.e. 7500 ohms =7.5 Kilo ohms
There are 15 different codes that GM uses in their V.A.T. systems. They are as follows, (1) 402, (2) 523, (3) 681, (4) 887, (5) 1130, (6) 1470, (7)1870, (8) 2370,
(9) 3010, (10) 3740, (11) 4750, (12) 6040, (13) 7500, (14) 9530, (15) 11800
Old Oct 30, 2005 | 10:18 AM
Engine: 5.7 TPI
I HAVE NO VIN THIS IS ON PROJECT PICK UP THAT I PUT A TPI IN
Old Oct 30, 2005 | 10:51 AM
Vader's Avatar
Since it's a project, you should have time to experiment. Try a value. If it doesn't work, wait ten minutes, then try another. Statistically, it should take you no more than six attempts.
My wild guess is that it will be the very last one you try, so start there first.
Old Nov 1, 2005 | 12:58 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Do you have the actual VATS module? It's separate from the ECM. The ECM needs a pulsed square wave ground signal before it will turn on the injectors. You can get a module to make this signal or get a PROM chip to eliminate it.
Old Nov 7, 2005 | 09:05 PM
Engine: 5.7 TPI
HEY FOUND AN EASIER SOLUTION PAINLESS MAKES A VATS BYPASS KIT SOLD AT SUMMIT PART NUM PRF-64023 VERY EASY TO WIRE IN
Old Nov 7, 2005 | 09:57 PM
Trah84Z's Avatar
Car: 1984 Z28 ~Brown Horse~
Engine: 305 V8
Axle/Gears: 3.23...i dunno...
you should really look into fixing that caps lock key also...
Old Nov 8, 2005 | 05:22 PM
Engine: 5.7 TPI
Bad habit
Street Lethal
Apr 30, 2019 12:14 PM
stalkier
Dec 6, 2015 11:25 PM
djmarch
Aug 19, 2015 12:07 PM
stalkier
Aug 13, 2015 12:59 PM
djmarch
Aug 9, 2015 05:27 PM
