Ignition wire colors!
Old Nov 2, 2005 | 10:26 PM
harpo_87's Avatar
Car: 91' Camaro RS
Engine: LO3 305
Transmission: Built 700R-4
im installing a power lock kit i bought on ebay, it says that i need to run one wire to my ACC on the ignition i dont know how running it to the ACC will prevent the car from turning on ( reason the instructions gave) but i dont know the wire colors if anyone can provide the wire colors for under the colum i would be very happy thanks alot!!
Old Nov 3, 2005 | 09:11 AM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
Here's a wiring guide for a Viper alarm which includes the necessary ignition wires/colors:
https://www.thirdgen.org/techbb2/sho...hreadid=322942
Old Nov 3, 2005 | 06:43 PM
harpo_87's Avatar
Car: 91' Camaro RS
Engine: LO3 305
ok so if im reading this diagram right im looking for a orange wire? is that correct? the orange wire is the ACC wire?
Old Nov 3, 2005 | 07:12 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Yep. Orange is hot only with the key set to RUN. I haven't seen this kit, but it makes more sense to me to have the power locks wired hot all the time (red wires). That's how the factory locks are set up. Also makes it a load easier to integrate with an aftermarket alarm.
One more thing: Those ignition wires are so thick that my 100W soldering gun wouldn't heat them enough to melt any solder. I had to use a propane torch. If you do this, be careful not to melt/set anything on fire.
No matter where you connect the power for the kit, please, please run a fuse (20A is good in most cases for power locks) as the only protection on the ACC line is a fusible link and would heat most small wires like a light bulb before popping.
Old Nov 3, 2005 | 07:31 PM
harpo_87's Avatar
Car: 91' Camaro RS
Engine: LO3 305
i have a wiring diagram if you would like to see it. cause it confuses the heck out of me!
Old Nov 3, 2005 | 07:42 PM
harpo_87's Avatar
Car: 91' Camaro RS
Engine: LO3 305
heres the diagram that was sent with it, i croped out some unessicary parts
Old Nov 3, 2005 | 08:04 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
OK...the power for the system appears to come directly from the battery and I'm guessing the ACC hookup is some kind of extra feature. Maybe it locks/unlocks the doors with key on/off. The system as a whole looks easy enough -- appears to be a fairly self-contained, modular way of doing the power locks. From the schematic, you just hook up +12V form the battery, ground and ACC & you should be ready to go.
As for the "...running it to the ACC will prevent the car from turning on..." part -- that doesn't make sense to me because other than the fact that that is not a necessary feature in a power door lock system, there would need to be a starter kill relay and there is obviously not. Maybe it stops the power locks from actuating based upon key on/off?
Old Nov 3, 2005 | 08:08 PM
harpo_87's Avatar
Car: 91' Camaro RS
Engine: LO3 305
yeah ok so back to the original Q i guess lol what color is that ACC wire??
Old Nov 3, 2005 | 08:22 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
That really depends on the function oif the wire that's connecting to it. Most installers consider "any ignition wire that is hot in RUN, but NOT hot in START" to be an ACC wire. Of course, there is an actual ACC position on the key which is a brown wire. This runs to the wipers and the radio only. All things weighed, it looks like they really do mean the orange ACC wire in the ignition harness.
Fun, huh?
Hellbillydeluxe
Sep 22, 2015 09:58 PM
LT1Formula
Aug 20, 2015 09:36 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
