V6 VATS Starter Enable?
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
'90 Firebird, Where is the starter enable relay located?
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Re: V6 VATS Starter Enable?
Now which of these do I have to ground, to bypass that starter enable switch?
Car: 1989 Iroc-Z
Engine: 5.7L TPI
i think i may have found it but it has a fat yellow small yellow fat green and either a brown or black with white stripe and once you take the white pin out and take the square fuse looking thing out what do you do then thanks buddy
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Why are you removing the white pin and taking the relay apart? All you have to do is disconnect the wire harness from the relay and put a jumper wire in the openings on the connector with the large yellow wire and the tan/black wire.
Gunner242
Dec 25, 2015 04:49 PM
