turn signal wont cancel off
Old Nov 28, 2005 | 11:25 PM
lukerene's Avatar
Car: 1982 t top,,z/28,
Engine: 409ci vortec
Transmission: all steel t700r4,1300 stall yahooooooooooo
when i use my turn signal arm on the steering column the , turn light indicator lights on the car work fine ,, but i have no lights on the instrument cluster and the turn signal arm wont cancel or return to neutral,,in other words i am driving around with my turn indicator lights on the car blinking off and on,,and i have no idea from inside the car, due to no lights on the dash and the arm wont cancel,or turn off,,its a pain in the butt,,,,,,,,from australia
Old Nov 28, 2005 | 11:59 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It is possible that the bulbs in the dash are burned out or missing. Also have you checked to see if the "turn signal cam follower" in the sterring column is missing or broken?
Old Nov 29, 2005 | 07:57 PM
Kingsnake2005's Avatar
Car: 86 Camaro IROCZ
Engine: Stock 305 with 89 TPI
Transmission: 700R4 w/B&M transpak
I have had to make many repairs on my cluster due to broken traces. If the lights aren't blown and you end up having to pull your instrument cluster, dont forget to check the traces on the back. You will notice alot of "pathways" or traces. You can check these with a digital volt ohm meter (DVOM). most DVOM's have a feature where they will beep if there is a short between the probes. Simply place one probe at the start of the trace and the other at the end... you should get a beep on everyone to indicate shorts, if not then you will need to do some repair work. Msg. back and i will outline how i repaired mine. Good Luck!
Old Nov 29, 2005 | 11:32 PM
lukerene's Avatar
how do i fix the broken copper plastic contacts between the circuits,,,,,,,how about the turn signal mechanism,,,,mine works sometimes if i jerk the steering wheel back, i can sometimes cancel the thingy
Old Nov 30, 2005 | 11:26 AM
Vader's Avatar
Like Trickster mentioned, you may need to inspect the cancelling cam and springs in the steering column. It's a good excuse to open it up, clean and relube everything, and maybe snug up the tilt base bolts.
Old Nov 30, 2005 | 02:30 PM
lukerene's Avatar
yeh i had this rotten thing apart a few times,,, the snap ring is hard to get off to get the plate off thats behind the horn,,,though i made a decompression clamp that works good,,,,,,,,everything seems to work,, till i drive it,,,startin to hate this thing,,,,,,,,,,,i will give it one more go thanks boys,steve in australia
Old Nov 30, 2005 | 07:59 PM
To repair broken circuits, I run a jumper wire from the bigining point to the end point of the circuit. So, being careful not to melt the plastic, soldier a 24 AWG wire from the start pad to the end pad. I usually use a razor blade to scrape some of the protective coating off the trace. You should end up with an exposed peice of copper to soldier to. Soldier one end of the wire to the section you scraped. Repeat this process on the other side of the broken circuit. Lastly, check the circuit using your DVOM to make sure it is good- you should have 0 ohms across the circuit. I finish it off by running electrical tape down the length of the wire sticking it to the "circuit pad" One more tip: There is a plastic panel that covers the bottom of underside of the steering column where it goes into the dash. Make sure to take this off as the screws may tear some circuits as you pull the cluster out. Good Luck
Old Nov 30, 2005 | 08:06 PM
I put lock washers on the tilt base bolts... More permanent fix
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
TrevinE
Sep 14, 2015 03:20 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
