help no key
Old Nov 29, 2005 | 03:35 PM
DansZ87's Avatar
Car: 91 Z28
Transmission: 700 R4
help no key
I lost my key to my 91 z28 its my everyday driver, and i dont have a spare key, its they with the chip what should i do?
Old Nov 29, 2005 | 03:40 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Contact your local GM dealer and see if they will cut one from the VIN #. Be sure and ask what documents you will need to prove ownership (registration, title, license etc). If you have ever changed the ignition cylinder this will not work.
Old Nov 30, 2005 | 03:17 PM
DansZ87's Avatar
Car: 91 Z28
key
ok, i went to my local dealer they said they can for 42 bucks
Old Nov 30, 2005 | 03:26 PM
Lo-tec's Avatar
Did it work?
Old Nov 30, 2005 | 05:10 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
if not then youll have to drill out the lock assembly and pull steering wheel and turn sig assembly to get the cylinder lock screw out so you can swap it
pull another lock cylinder from another vehicle to put in or go buy a new one
ive had to swap my 82 trans am one about 4 times now cuz somehow i keep losing the key to the locks i swap into it everytime and it only happens with this car for some odd reason..
even after trying all the keys i have, a coffee can full.,
its crazy.,
good luck
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
Gunner242
Dec 25, 2015 04:49 PM
Linson
Oct 1, 2015 09:50 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
