Power Antenna
Old Dec 20, 2005 | 11:30 AM
BLURR's Avatar
Car: 1989 Iroc Z
Engine: 5.7 TPI
Power Antenna
Ok my 89 Iroc has the factory power antenna in it. Well the thing is stuck in the up postion and when you shut the car off you can hear the motor trying to pull the antenna back down. Guess its stripped or burned up. Anyways I wanta replace the thing with a new one.
I called the dealership yesterday and they say a new one is a $189.00. I dont want one of those cheap aftermarket things that crap out after a month. Is there a way to get a new one cheaper than through the dealership? Some kinda parts place for 3rd gen Camaros?
I have a brand new power antenna for a 93-02 Trans Am, but I pulled the fender liner out of the Iroc yesterday and it doesnt look like it will work.
Any ideas or help would be great guys.
Old Dec 20, 2005 | 11:38 AM
Firebat's Avatar
get the part number and check out gmpartsdirect.com. They charge shipping but most of the time they are cheaper for gm parts.
Old Dec 20, 2005 | 12:04 PM
BLURR's Avatar
Car: 1989 Iroc Z
Engine: 5.7 TPI
Does anyone have the part number for it?
Old Dec 20, 2005 | 12:41 PM
Firebat's Avatar
Call up your local GM dealer and ask them.
Old Dec 20, 2005 | 01:31 PM
BLURR's Avatar
Car: 1989 Iroc Z
Engine: 5.7 TPI
Says no part found for the part # the Chevy dealer just gave me #1017.
Also they didnt show the $20 repair kit to fix it.
Old Dec 22, 2005 | 12:59 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
The full part number is 88891017. The price shipped fom www.gmpartsdirect.com is about $120. An example picture is below.
The cable within the mast of your antenna probably broke. I am in-process of a similar repair. I plan on replacing just the cable. I believe the $20 kit you mentioned is the 22038195 cable kit.
Old Dec 22, 2005 | 05:42 PM
BLURR's Avatar
Car: 1989 Iroc Z
Engine: 5.7 TPI
Thanks man, thats just what I was looking for.
I suck at the interweb. LOL
Old Dec 28, 2005 | 10:50 AM
Blue_IROC_86's Avatar
Car: '82 Camaro Z28 (Former Pace car)
Engine: 85 5.7L Small Block
Transmission: WC T5
Axle/Gears: 96 disc LT1 3.23 Auburn 10 bolt.
hey where can i get a new mast for my power antenna?
Old Dec 30, 2005 | 07:43 PM
MechCD's Avatar
Car: '92 Camaro RS, '93 Ranger
Engine: LO3, Vulcan
Transmission: 700R4, M5OD
Axle/Gears: 2.73, 3.45
Would an aftermarket one hurt? Autozone has a few in the $20-$30 price range for an entire power antenna kit. You could steal the connectors off the old one.
$100+ for an antenna seems very overpriced
Old Oct 22, 2011 | 06:30 PM
b-benny's Avatar
Re: Power Antenna
I gave the guys at AntennaMastsRus a call 1-920-686-0644 and they set me up with a replacement part-last metal section and the plastic cord, one piece-my motor works. This fits the AC Delco OEM motor $23.50. They called it MSTGM6 cable
My problem is that the antenna is stuck up and I can't get it down to get it out. The top section is part of the replacement cord so I can't cut it at the bottom 2 sections
Any ideas???
83 Crossfire TA
Jan 3, 2016 01:26 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
sailtexas186548
Aug 24, 2015 10:11 PM
