Tail lights/parking lamps/gauge lights not working need help
Old Dec 26, 2005 | 01:17 AM
1979_transam's Avatar
Car: 79 Trans Am & 99 Z28
Engine: 403, LS1
Transmission: turbo 350, 4L60E
Axle/Gears: 3:42s baby
I just bought a 91 formula 305 tpi last week. the gauge lights/tail lights/ parking lights all worked fine for like 2 days. then i noticed someone hooked up neons in my interior. so my dumbass just grabbed the neon and yanked and broke the wire, not knowing where it led. so that night when pulling the car outa the garage, i noticed that the gauge lights were not working and neither were my parking lights or tail lights. but my turn signals and brake lights worked. so the next day i try and figure it out. i pulled out my console and front carpet to see where the neon wire i pulled led to but i couldnt find it. so i checked the fuses and the 20A tail fuse was blown so i repaced it and as soon as i turned on my headlights, the fuse blew. this has been bugging me the past few days because i can't figure this out. i dont know if this is any way related to the wire i pulled from the neons or not. i didnt check the gauges or tailights or anything before i worked on it that day. i'm hoping that maybe its just a bad ground or something. any ideas? or has this ever happened to anyone before? does any one have any wiring diagrams for a 91 firebird? any help would be much appreciated.
Old Dec 26, 2005 | 07:12 PM
Vader's Avatar
I dount that it is a bad ground, but a really good ground where you ripped the wire out. Find that source, and you'll probably find the problem.
You can find diagrams here:
http://www.autozone.com/servlet/UiBr...3d801eef19.jsp
Old Jan 8, 2006 | 08:43 PM
Engine: 403, LS1
anyone else have any advice?
Old Jan 8, 2006 | 09:43 PM
xomega's Avatar
Car: 1990 chevy camaro rs
Engine: lt1
Transmission: 4l60e
Axle/Gears: 273:(
beat the person @$$ who hooked up the neon?:P
Old Jan 9, 2006 | 06:07 PM
Engine: 403, LS1
Haha I would if i knew who did it. Honestly who puts neons in a firebird? Its not a *** damn honda civic. they even drilled a hole on the top of my shifter plate to put the gay *** switch. so now i have a huge hole right above my power mirror switch. I wanna maybe put a ws6 emblem or somethin to cover it instead of payin $100 for a new shifter plate.
Old Jan 9, 2006 | 06:21 PM
xomega's Avatar
Engine: lt1
Transmission: 4l60e
Axle/Gears: 273:(
who all drives your car. and is probably a teenager
Old Jan 9, 2006 | 11:04 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I believe vader is indicating the power wire to the neon you ripped out is contacting a good ground.
If you find where you ripped it (the neon) from, you'll find the source of your problem.
Old Jan 10, 2006 | 01:48 AM
Engine: 403, LS1
yea but the problem is i cant find where that wire is. there are tons of wires that somebody messed with under there and diconnected and i have no idea what goes to what. and the wiring diagrams all look like chinese to me. you think it could possibly be a faulty switch??? cuz the switch could effects all my symptoms. but my headlights work on the switch.
Old Jan 10, 2006 | 01:51 AM
Engine: 403, LS1
as of now i am the only one that drives the car. i didnt buy it off a teen but my guess is that he did. i know the guy i bought it from didnt put the neons in. whoever did, did a hack job on it anyways
Old Jan 17, 2006 | 01:50 AM
Engine: 403, LS1
help please
Old Jan 17, 2006 | 11:19 AM
Vader's Avatar
Since we do not have the vehicle in front of us, we cannot trace the wiring. There is obviously a lighting circuit grounded somewhere. It is either a wire, or possibly the instrument panel dimmer module transistor has an E-B short. It will be your responsibility to locate it. You have the link to the necessary diagrams.
Old Jan 17, 2006 | 05:57 PM
Engine: 403, LS1
thanks, i was just wonderin if this has ever happened to anyone before. seems kinda odd to me
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
Fronzizzle
Aug 19, 2015 01:36 PM
Omega
Aug 10, 2015 12:46 PM
