86 tpi camaro firewall wire question
Old Dec 27, 2005 | 02:47 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
what is the 2 wire plug coming out of the drivers side of car through the firewall with the other bundle of wires? it is about 2 inches long and it was pluged into the tpi harness. . i have removed my tpi and computer and this connector was the only one connecting the engine wiring on drivers side to the computer wiring on the passenger side for the ecm and controls. my thoughts are fuel pump wires, or the oil pump pressure switch wires that were tied into the fuel pump wiring, or temp guage wires. i no its not the ac clutch compressor wires as those are alot longer and i have identified them.....
any help would be awesome
Old Jan 1, 2006 | 05:57 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
someone has to know what this 2 wire plug is for. the colors are green the other is brown.
Old Jan 1, 2006 | 10:01 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
without seeing a pic of what you are talking about, i believe the plug you are talking about is the coolant temp (green) and the alternator wire (dark brown).
Old Jan 2, 2006 | 05:26 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
First try at uploading a pic, hope it works...
Old Jan 2, 2006 | 05:56 PM
1981LT1's Avatar
Engine: LT1; LT1
the green wire is the coolant temp wire and the brown looks to be the oil presure wire.
Old Jan 2, 2006 | 06:24 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
the brown wire has 8.5 volts with reference to ground with key on is this odd?
Old Jan 2, 2006 | 08:07 PM
1981LT1's Avatar
Engine: LT1; LT1
that could possibly be the voltage wire at the alternator. Is the bat voltage the same as the wire voltage?
Old Jan 3, 2006 | 05:07 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
alt wire is 12.5 same as batt volt. and the switched alt wire (yellow) is also 12.5 with key switched on. so alt wiring is all functional.
Old Jan 17, 2006 | 07:11 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
I need my fuel pump wires to run my pump. Is this one of them by chance?
Old Jan 17, 2006 | 09:29 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
come on please. im getting desperate i need my fuel pump wiring...
Old Jan 20, 2006 | 12:40 AM
1981LT1's Avatar
Engine: LT1; LT1
I am almost positive that has nothing to do with the fuel pump. Let me look at my old TPI harness and figure it out.
Old Jan 21, 2006 | 12:22 PM
b_the_j's Avatar
Car: 92 RS
I believe that is a blank connector for an options that didn't come on your car, the best way to figure it out would be a wiring diagram. if you don't have a haynes or chilton(both of which are almost completely useless), check out this http://www.autozone.com/servlet/UiBr...3d80163fb5.jsp
forget about that connector and look for your fuel pump wires coming from one of the relays right next to where you are looking
Old Jan 21, 2006 | 02:16 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
the relays are gone. sold to buyer of my complete tpi. these are the only wires coming into the engine bay without a home.
Frozer!!!
Jan 19, 2024 04:55 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
squiggy2
Aug 9, 2015 09:30 PM
