Key Security
Old Jan 26, 2006 | 07:34 AM
wheelstandin87's Avatar
Car: 87, 88 and 89 Iroc-Z
Engine: 305, and 350
Transmission: 700R, and T-5
Axle/Gears: 3:23 POSI
Key Security
I bought an 89 Iroc-z and sometimes it doesnt start im pretty sure that it is the little security thing on the key? Im thinking that i would like to see if you can do away with that security system all together and if you can can someone tell me how?
Old Jan 26, 2006 | 04:21 PM
Firebat's Avatar
do a search for removing the vats. Vehicle anti-theft system. Basically you measure the resistor in the key with an ohmmeter, then buy a resistor with that value and solder it to the two wires that would go to the resistor in the key.
this is from the thirdgen.org tech articles section
https://www.thirdgen.org/newdesign/tech/vats.shtml
Old Jan 27, 2006 | 10:34 AM
Vader's Avatar
Or just clean the key pellet and contacts within the ignition lock cylinder.
Old Jan 27, 2006 | 12:22 PM
Firebat's Avatar
true, i would try to keep the vats if you can.
RS Reaper
Oct 17, 2018 07:52 PM
Gunner242
Dec 25, 2015 04:49 PM
Linson
Oct 1, 2015 09:50 PM
FormulaEngland
Sep 30, 2015 01:50 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
