Trailer wiring from factory?
Old Mar 5, 2006 | 10:46 PM
WillSpeedy's Avatar
Car: 88 Iroc Vert/ 1980 Z28
Engine: 305 TPI/ 350
Transmission: 700R4/ TH350
Axle/Gears: 2.73posi/ 3.08 Open
I was poking around the trunk of my vert, taking panels off to get the audio started, and I found was looks like a trailer wiring harness 4 wires and a connector at the end. The 4 wires all stuck together. I tried to take a pic but I am out of batteries.
Is this what it is?
Old Mar 5, 2006 | 11:42 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I can't imagine its factory since they didn't come with trailor hitches and I've never seen it in any other bird/maro.
Old Mar 10, 2006 | 03:19 PM
WillSpeedy's Avatar
I got batteries for my camera. And took these pics. there is 2 plugs and 6 wires in total they all go to a black box in the drivers side corner of the trunk(convertible) as well as the wires for the taillights.
Old Mar 10, 2006 | 03:26 PM
WillSpeedy's Avatar
The site won't let me post a pic? I have done it before.?????
Old Mar 10, 2006 | 03:44 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Attach the pics. But they cannot exceed certain size. Watch out for that too.
Lou
Old Mar 11, 2006 | 10:57 AM
WillSpeedy's Avatar
pic?
Old Mar 11, 2006 | 10:59 AM
WillSpeedy's Avatar
pic2
Old Mar 11, 2006 | 11:03 AM
WillSpeedy's Avatar
pic3
Old Mar 12, 2006 | 03:24 PM
WillSpeedy's Avatar
bump
Old Mar 13, 2006 | 10:31 AM
BigBadLou's Avatar
Engine: TPI
Yup, that sure looks like trailer wiring connector.
Did you test it to see if it works right? I'd sure love to see a Camaro tow something.
Lou
Old Mar 13, 2006 | 11:06 AM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Doesn't surprise me. My TA had the wiring back there as well.
I've seen quite a few thirdgens with trailer hitches unfortunately.
Old Mar 13, 2006 | 11:10 AM
BigBadLou's Avatar
Engine: TPI
Heck, I've seen a Festiva pull a 20ft-er behind it .... now that didn't end happily ...
http://video.google.com/videoplay?do...76307279476521
Old Mar 13, 2006 | 11:20 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Old Mar 13, 2006 | 09:51 PM
WillSpeedy's Avatar
That's Hilarious.
thanks for the input. My car doesn't have a hitch. But the wiring seems to be there? I think I zip tie it in a ball to clean up the rats nest behind that panel.
Old Mar 14, 2006 | 08:42 AM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
Guddaamnnn
Old Mar 14, 2006 | 08:58 AM
BigBadLou's Avatar
Engine: TPI
Will, did you check if there used to be a hitch connected/bolted/welded somewhere on the frame? Towing with a unibody never does any good to the car so I would make sure everything's all right. The wires aren't there just for fun, somebody towed with your car in the past, most likely.
Lou
Ikes 91Z
Dec 9, 2015 03:49 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
overdriv
Aug 20, 2015 03:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
mx127
Aug 10, 2015 08:13 AM
