identify this sensor please
Old May 3, 2006 | 08:26 PM
FireHwk's Avatar
Car: 92 camaro vert.
Engine: 305 TBI
Axle/Gears: 4th gen with 3:42
its on the passenger side of the engine of a 305 tbi
Old May 3, 2006 | 08:36 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
You say its on the passanger side? Kinda looks like a coolant temp sender thats had the terminal broke off or something. On my 86 TPI, it's on the drivers side though. Not 100% sure what that is on yours.
Old May 3, 2006 | 08:40 PM
FireHwk's Avatar
Engine: 305 TBI
well it did have something plastic attached to it but it broke off. heres a pic of it.
Old May 3, 2006 | 09:23 PM
Brads RS's Avatar
Thats a coolant temp sender for... Gauges, AC, or AUX coolant fan.
Old May 3, 2006 | 09:24 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Pass side is for the "Fan Switch". There should be a loose black wire somewhere around there. Ground that to the engine block and the fan will kick on.
Old May 3, 2006 | 09:55 PM
FireHwk's Avatar
Engine: 305 TBI
well i took it off and coolant started coming out. I looked at the sensor itself and it doesnt seem like it can be replaced. am i doomed..?
Old May 3, 2006 | 09:59 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Yep they can be replaced for about 10 bucks
Old May 3, 2006 | 10:04 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
That is the secondary (heavy duty) coolant fan switch if you have the dual coolant fans. If you have just the single coolant fan it is the coolant fan switch. No need to add primary to that since it would be the only switch for the fan.
SS-EXPRESS
Sep 28, 2015 09:14 AM
tattmann
Sep 27, 2015 05:20 PM
efiguy
Sep 27, 2015 01:30 PM
wstephan96
Sep 25, 2015 04:28 PM
