Whats the consequences of this wiring problem exactly?
Old May 7, 2006 | 07:39 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
Main orange power wire near oil pressure switch connector being frayed through and half broken, and both sets of ground wires on both cylinder heads being finger tight. How would you expect the car to run?
Old May 7, 2006 | 07:59 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
mis firing probably for having bad grounds
Old May 7, 2006 | 09:20 PM
funny you say that cause the car was intermittently running bad
i could never pin point it. I sent the wiring harness off to tpi parts.net to be reconditioned, and transferred over to the oval style relays while they were at it. Hopefully this will clear up my problems.
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Bert87
Aug 23, 2015 03:50 PM
Fronzizzle
Aug 17, 2015 02:52 PM
