"Check Engine Light" - Code 13
Old Jun 4, 2006 | 07:00 AM
supersuit99's Avatar
Car: 84 Trans Am
Engine: V8 305
Hi everyone,
A little backstory first - I have a 1984 Firebird that I recently removed the stock 305 and replace it with a 350. I removed all emissions stuff and put headers on it. I did replace and re-install the o2 sensor, though. I kept the stock carb and manifold too. When I drive, the check engine light will come on. It's code 13 which is for the oxygen sensor. The car runs great it's just the check engine light keeps coming on. Any idea what the problem is? Would it hurt the engine in any way to just remove the check engine light?
Thanks,
J
Old Jun 6, 2006 | 01:10 AM
mark wells's Avatar
Car: 85 Trans Am
Engine: 383 ci
Axle/Gears: posi 342
Sounds like either 02 sensor is bad or is not connected. possible burn through wire on new exhaust. You can check if sensor is good by using ohm meter. Let me know if you do not know how to perform test.
Old Jun 7, 2006 | 12:26 PM
Car: 84 Trans Am
Engine: V8 305
I replaced the O2 sensor with a new one, however I had to splice about 4 foot of wire on to it so it could reach the threaded hole on the header. I'll check the wire though for melting....however, the car runs great now anyways, so if that's not the problem, will it hurt to just pull the Check Engine bulb and leave everything as is? Code 13 is the only code the ECM is showing....
Thanks,
J
Old Jun 7, 2006 | 11:26 PM
Green89IROC305's Avatar
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
i f you pull the check engine bulb how will you know if you get future codes?
Old Jun 19, 2006 | 11:20 AM
Car: 84 Trans Am
Engine: V8 305
I replaced the O2 sensor with a new one and the Check Engine Light still comes on with code 13....could it be anything else? I did remove all emission stuff when I put my 350 in, but I reinstalled the O2 sensor in the header.
Thanks,
J
Old Jun 20, 2006 | 08:44 AM
Slave One's Avatar
Car: 1991 Camaro RS
Engine: 5.0 TBI
Axle/Gears: 3.08
Had this same problem on my 92 305TBI...
(takes deep breath)...
whats happening is when you first start the car in the morning and its cold, the computer runs the engine in "Open Loop" mode where it does not listen to the sensors until a couple of things happens... Engine warms up to certain temperature and O2 sensor starts to get a reading and a couple other things I'm not certain of... but all these things has to happen or it stays in Open Loop... the computer is getting no signal from the O2 Sensor so it throws Code 13 at this time...
The computer has a designated ground wire that comes out and bolts behind the drivers side head (at least on my 305TBI) along with a couple other wires...
I cut these wires and didnt even think twice whenever I first got the car and replaced the drivers side head gasket (bolt wouldnt come off)... Could not for the life of me figure out what I did wrong until someone sent me a schematic from the official GM book for CODE 13... all I did was cut the wire at the PCM and ran another wire from there to a ground close to the O2 sensor and VIOLA! No more code 13...
At the time, I am not certain of exactly which wire, have to check the schematic when I get to my home computer...
Old Jun 20, 2006 | 10:01 AM
Car: 84 Trans Am
Engine: V8 305
Okay sounds good....please post the schematic when you get the chance!
Thanks,
Joe
Old Jun 20, 2006 | 08:47 PM
Slave One's Avatar
Car: 1991 Camaro RS
Engine: 5.0 TBI
Axle/Gears: 3.08
Well, here you are...
Old Jun 20, 2006 | 10:18 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Just as another little thought here, I had a 1985 Z28 with the 305 engine in it and was getting the code 13 also. After changing two O2 sensors and still having the problem, I borrowed the dealers service manual and found the problem was a mis-adjusted throttle position sensor. Adjusted it and never had the problem again.
Wade787b
Sep 29, 2015 01:15 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
