High beams not working
Old Jun 15, 2006 | 09:21 PM
Beachmonkey6's Avatar
Car: '88 GTA
Engine: L98 -350TPI
I just got my '88gta about a month ago and I cant get the high beams to turn on. when i pull toward me with the signal switch, it just moves freely and doesnt click or anything. What should i do? Also, is there a light on the dash that lights up when the brights are on? Thank, -Austin
Old Jun 15, 2006 | 11:13 PM
Vader's Avatar
Yes, there is a blue high beam indicator lamp on the I/P.
The low/high beam switch at the base of the steering column is actuated by a linkage rod from the lever you pull. Try changing the tilt position of the steering wheel to see if it will take up any of the slack and operate the low/high switch. If so, the switch may require only some adjustment. If tilting doesn not help, the switch may be WAY out of adjustment, failed, or the linkage rod may have fallen out.
Old Jun 15, 2006 | 11:22 PM
Car: '88 GTA
Engine: L98 -350TPI
ok well the blue high beam indicator light does come on when i turn the lights on, so i guess the high beams are just stuck on. Ill try messin with the stearing wheel and see what happends. Thanks.
Old Jun 15, 2006 | 11:59 PM
sicc87's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: auto 700-r4
yeah the little rod that goes into the column bends sometimes cause of the tilt feature.. try tilting it in other positions and it should click.
Old Jun 29, 2006 | 12:41 PM
1991Camaroz28's Avatar
Car: 91 Z28
Transmission: TH700-R4
Sure is better than having them stuck on all the time
I installed a floor swith and have no problems with that. Sometimes i step on it accidentally and blind people
Old Jun 29, 2006 | 10:07 PM
Car: '88 GTA
Engine: L98 -350TPI
Yea... tilting the wheel around doesnt do anything. So i dunno... i might just leave it the way it is.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fronzizzle
Aug 19, 2015 01:36 PM
jackhammer
Aug 15, 2015 10:04 PM
BBSDesigns
Aug 11, 2015 07:39 PM
