86 Firebird Hatch Release Wiring
Old Jul 8, 2006 | 08:46 PM
Firebat's Avatar
Trying to figure out the wiring on an 86 firebird with an automatic. It is different wiring than camaros, 91-ish-92 firebirds. The problem is the hatch release button only works if the e-brake is on.
Its a 3 wire hatch release relay. What i know is the black/white wire from the switch goes to the relay. The Black wire goes from the relay to the hatch release in the back of the car. The tan/white wire goes to the e-brake switch.
Where does the P/N switch wire into this circuit at, physically? I want to know which wire is used from the P/N switch and where it physically splices in at. Where does it hook up to the relay at? Or does anyone have a schematic on this for an 86 bird?
Old Jul 11, 2006 | 10:20 AM
super_kev's Avatar
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
In a '85 T/A (I assume it's identical to an '86) it does not play a part in it.
The tan/white (ground) wire goes to the following:
-e-brake switch (closed w/brake applied)
-Brake pressure switch (near brake fluid reservoir, closed w/unequal brake pressure)
-Ignition switch (grounded in off and bulb test)
All three connect at splice 228, which is below the light switch.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
Randomtask2
Aug 13, 2015 01:57 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
